Hi Folks,
I have a Hafler DH-500 Power amplifier. It is, of course, secondhanded, but sounds very good. As you know, it has an AC cooling fan to be operated in the case of the heat sink overheated. But the cooling fan is operating immediately after pushing on the power switch. What would be the problem? I think this cooling fan has 3 stage of operation from the schematic diagram. Is that right? So, there may be a problem in the thermal sensor(thermostats, TS401 and TS402 in the schematic diagram), I think. I want the specifications of the thermal sensor(normally-open type? setting temperatures?) for the replacement. Recommended parts? Or any possible problems? Appreciate any help. Last edited by fossil8836; 12th April 2010 at 01:47 AM. Reason: Attaching a image file |
#2 |
You have described a normal functioning amplifier.
The fan is supposed to rotate as soon as the power switch is turned on. As it heats up it will switch to medium speed, and then high speed. If you test it at 4 ohms it will move quickly through all three speeds, and then go into thermal shut-off (and the power switch will blink). The fan switches are about 55°C, the shut-off is about 85ºC.
Candidates for the Darwin Award should not read this author. |
#3 |
Thanks for your notice about my misunderstandings.
I think I have to be patient with the fan noise. Is there any tweak for reducing fan noise of this amplifier? |
| Hafler DH-500 problems... ugh! DH500 | nifaron | Solid State | 7 | 11th November 2008 06:25 PM |
| Hafler DH-500 Questions | mtflycaster | Solid State | 9 | 6th August 2008 12:29 AM |
| Selling some Hafler DH-220/DH-500 transistors | housing | Swap Meet | 0 | 10th May 2007 03:43 PM |
| Hafler DH-500 Protect Circuit Problems | wangro81 | Solid State | 4 | 9th October 2006 11:02 PM |
| Hum in Hafler DH-500 | Bogie | Solid State | 3 | 5th March 2006 03:56 AM |
| Page generated in 0.07193 seconds (69.38% PHP - 30.62% MySQL) with 11 queries |
