Old 11th April 2010, 06:10 PM   #1
Default gk 800rb probs
Hi Folks,
I have a GK800 RB that's been completely faithful for years. Never abused, always plugged in to 8 ohms. Suddenly it is making a rude distortion sound. I suspect the problem may be in either the frequency pot, the bi-amp push-pull switch, or in whatever circuit they share (which may be the whole amp for all I know).
I suspect this because the frequency pot generates popping sounds when turned, especially to its extremities, and the push-pull switch is full of static-like noise. None of the other pots or switches is a problem.
I'm wondering if I should just replace the whole board.
Appreciate any help.
Old 11th April 2010, 11:12 PM   #2
lots of GK info here Audio GallienKrueger : Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
Is the distortion in the line out, or DI out, if so, the distortion is from the pre amp, otherwise from the power amp.
Start at the input, trace teh signal through the amp, once you find which section is distorting, you can fix it.
If you are not sure, maybe an amp tech is your best bet
Old 12th April 2010, 12:48 AM   #3
Terry Demol's Avatar
Originally Posted by flatarchtop View Post
Hi Folks,
In addition to above suggestions check main PS - return. Some GK's use
rear speaker 1/4" jack connector as the return point and if it works loose
can cause a problem.
cheers
Terry
need help with gallien krueger 800rb dkdeleon Solid State 19 3rd June 2010 09:27 PM
Gk-71 Vladi59 Swap Meet 0 23rd March 2009 05:02 PM
Blown up GK 800rb mpm32 Instruments and Amps 1 13th April 2007 09:20 PM
Capacior leak on my GK 800RB jeyvi Solid State 5 26th December 2005 09:46 AM
Page generated in 0.08430 seconds (71.38% PHP - 28.62% MySQL) with 10 queries
