Old 10th April 2010, 11:59 PM   #1
genther is offline genther  United States
Default Counterpoint SA-100 Fix
Hello,
I first will admit I am self taught in electronics and have many holes in my knowledge base. That being said, I would greatly appreciate any direction sent my way.
I have an SA-100 with a blown channel and was able to find a matched set of MOSFETS from an other SA-100. I installed them in the channel that was working on mine and they worked fine. When I install them on the blown channel I am experiencing a problem. I replaced the 10v zeners and the gate resistors and triple checked everything. I have a 1 ohm resistor over the positive rail fuse clips and am getting 40mv across the resistor at 25% nominal voltage with the gates shorted to ground. I'm not sure where to look for the problem.
Thanks,
David
Old 11th April 2010, 12:28 AM   #2
Hold on, I just took a reading of 0.00 ohms between the source & drain on the P side. I will report my findings...
Sorry, I neglected to properly drain the main caps and there was enough voltage to keep the MOSFETS turned on. The problem stated above still persists.
Old 11th April 2010, 02:57 AM   #3
Never mind. I found the problem and I won't embarrass myself by explaining.
Counterpoint SA-100 with Exicon MOSFETs woodman Solid State 27 21st May 2010 05:32 AM
COUNTERPOINT SA-100 Upgrade or Sell Pdspecl Everything Else 6 8th November 2006 02:47 PM
Counterpoint SA-100 again! AxFe Solid State 14 30th October 2006 07:46 PM
counterpoint sa-100/sa-220 schematics? Williams Audio Solid State 14 1st June 2006 09:47 AM
counterpoint sa-100/sa-220 schematics? Williams Audio Analog Line Level 3 24th February 2006 05:46 PM
Page generated in 0.07276 seconds (65.24% PHP - 34.76% MySQL) with 10 queries
