Old 10th April 2010, 04:08 PM   #1
Glen B is offline Glen B  United States
Default Amp makes whistle sound after turn off
What would cause an otherwise normally functioning amp to make a whistle type sound a few seconds after power is turned off ?
Old 10th April 2010, 04:13 PM   #2
moschfet's Avatar
I would estimate, that are oscillations. Have you got an Oszilloscope?
Old 10th April 2010, 04:17 PM   #3
PhaseLockLoopy's Avatar
imbalance in power rail fall off causing instability - causing momentary oscillation in RC parts of the circuit -
Most good amplifiers return the Speaker solenoid first before powering down the rails
Hum likes to have a nice "Noise to Signal" ratio
To "Hum" is to be noticed Quality hum is when it pours out of Electrostatic speakers
Old 10th April 2010, 04:43 PM   #4
The amp does not have output relays. Is there anything that can be done or does one have to live with the noise ?
Old 10th April 2010, 07:42 PM   #5
Is it an older Yamaha?
We installed 100+ in a stadium. On powering down they all did that. We nick-named it the Yamaha Fart
Old 10th April 2010, 08:16 PM   #6
Its a Rotel.
Old 11th April 2010, 03:46 AM   #7
sumaudioguy's Avatar
Yah like they say oscillation. Could be the rails but probably some section is loosing bias while another section is still functioning with the falling power supplies. With the no bias the compensation does not work and off it goes into oscillation. How to fix? How about a different amp?
What the other guy said----Standing on the shoulders of giants.
New avatar- no more little array
Old 11th April 2010, 05:30 AM   #8
Thank you for the replies, and insight into the problem.
My alpine amp makes a high pitch squeaking sound weesatron Car Audio 67 29th October 2008 09:49 PM
Freaky Whistle in Guitar Amp Trout Tubes / Valves 47 9th January 2006 05:42 PM
With one makes more sound! destroyer X Solid State 43 8th June 2004 11:11 AM
What makes different speakers sound ... different? cuallito Multi-Way 16 14th April 2004 01:13 AM
What makes the most sound improvement? BlackDog Chip Amps 19 29th February 2004 07:56 PM
Page generated in 0.08334 seconds (72.96% PHP - 27.04% MySQL) with 10 queries
