Old 9th April 2010, 05:07 PM   #1
81bas is offline 81bas  Germany
Default How loud is 250uV white noise?
Hi all!
In the specs for some A/V receiver with AB amplifiers inside is written SNR 110dB and RMS background noise voltage 250uV. How loud is such noise applied to the speakers? Will be this noise audible? From which distance to the speakers?
Thanks!
Old 9th April 2010, 05:19 PM   #2
Send a message via AIM to SpeakerScott Send a message via MSN to SpeakerScott Send a message via Yahoo to SpeakerScott
Originally Posted by 81bas View Post
Hi all!
Thanks!
That would be 0.0000000078125 watts into an 8 ohm load. Very quiet. Most amps I've ever owned had an audible hiss when placing your ear very...very...close to the tweeter.
-Scott
www.stuffscottbuilt.com
Old 9th April 2010, 05:19 PM   #3
We do not have enough information yet to guess at this answer.
Your speakers will have a specification that translates voltage (usually 2.83 volts) to a dB SPL output at 1m away (sensitivity or perhaps effciency). This will be in the range of 85 to 105 dB per 2.83 volts.
At 250 uV you will be about 80 dB below this. Whether this is audible or not can not be determined exactly. Please remember these numers should be weighed against the noise floor in the room iteself.
I have not bothered discussing some of the 2nd order effects in this analysis. Others may feel the need to go crazy over htose details.
Good Luck,
-Tom
Old 9th April 2010, 05:21 PM   #4
event horizon's Avatar
If that spec is real i should imagine there would be the deafening sound of silence within an foot of the speaker. After all that kind of noise will put 0.000000007 W RMS into it Or 7 billionths of a watt
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Last edited by event horizon; 9th April 2010 at 05:35 PM. Reason: billionths, not billions lol
Old 9th April 2010, 05:34 PM   #5
wahab is offline wahab  Algeria
Hi all!
Thanks!
The 110db S/N ratio is surely specified at full output level.
At 250uV , S/N ratio would be about 81dB relative to a 1W
output level on a 8 ohm load. (2.828V rms)..
Not a bad value, although a good amp will be have
three times less noise..
Old 9th April 2010, 05:43 PM   #6
Ok! Many thanks for the answers!
White Noise Active PSU ANDYLASER Swap Meet 5 12th January 2009 06:37 AM
Choke, filter for white noise grandcanuck Analog Line Level 0 10th September 2008 04:20 PM
White Noise, Protruding woofer Code Class D 6 16th January 2008 06:02 PM
White Noise Audio closing down peranders Everything Else 0 19th April 2006 08:45 AM
HELP: White or Pink noise problem Tedyp Parts 2 26th March 2006 10:42 PM
Page generated in 0.08201 seconds (78.02% PHP - 21.98% MySQL) with 10 queries
