Old 9th April 2010, 09:54 AM   #1
SSDIY is offline SSDIY  Hong Kong
Default Question About Pre-Amp Schematic
Hi Gents
I am studing a pre-amp schematic which is the ASR Collector I got from this forum earlier. I have a question about the connection of the emitter of the bipolars BC549/559.
According to the schematic, the emitters of the two BC559 are connected to the + rail while the collectors of the two BC549 connected to the - rail.
As far as to the other pre-amp schematic I have reviewed before, if the emitter of a bipolar is connected to the + rail, then the emitter of the other bipolar should also be connected to the - rail.
I would like to know if the connection of the bipolars of this schematic is correct but it is working on antoher way or it is a drawing error.
Please advice, thanks.
Old 9th April 2010, 12:43 PM   #2
wahab is offline wahab  Algeria
The said stage is a cascode, and i think that the bottom
side is erroneous as you point it..
Old 9th April 2010, 12:44 PM   #3
knutn is offline knutn  Norway
Originally Posted by SSDIY View Post
Hi Gents
It is a drawing error. The three lower BC549 have their collector and emitter exchanged.
Old 10th April 2010, 12:37 AM   #4
Hi wahab & knutn
Thank you for advice. I will correct the schematic accordingly.
Old 15th April 2010, 08:58 AM   #5
One more question about this schematic.
What is the function of the two trim pots connected to the +/- rails? To adjust output bias current or offset? Would anyone please advice?
Old 15th April 2010, 06:53 PM   #6
It is for adjustment of the output bias current.
Old 16th April 2010, 01:57 AM   #7
Thank you knutn, really appreciated.
12AU7 Pre-amp Schematic Question Jimthemeek Tubes / Valves 4 3rd May 2009 06:20 PM
looking for a pre-amp schematic steamPunk Tubes / Valves 3 3rd August 2008 01:49 PM
Pre amp? What schematic do i need? silentblackhat Solid State 21 16th March 2006 06:47 AM
pre-amp schematic RichardJones Solid State 4 22nd May 2003 10:58 PM
Pre amp schematic HKC Solid State 2 10th January 2003 06:07 AM
Page generated in 0.07514 seconds (83.82% PHP - 16.18% MySQL) with 11 queries
