#41 |
just another comercial product with nothing realy special to talk about ...
yet again the same story ... all caps replaced all switches and pots cleaned nothing to tune in the amplifier japanese designer of these and previous "brown" models of kenwood was so sure about the parts that VBE is runing from a standard resistor and no trimmer often depenting o the costumer and the use of the product i replace those with a trimmer in order to beef the bias up to so persentage to gain bitsof quality ... even though musical and quiet amplifier ... still is a lower than average design of the 80s at least compairing to now days machines remains both negative and positive that all this kenwood family uses a passive tone control that uses signal from the outpout to operate ....positive since with a proper and easy speaker can produce nice sonics and negative since long cables and strange loads will almost make it unstable reagards sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#42 |
ALESIS RA 500...
dont really know if this is real alesis product or some other factory that have some arangement with Alesis cheap small amplifier ( size and power ) sound is quiet good for a classic efp /Vi limmiter design .... amplifier is very balanced nothing is too much or too litle ...Vi limmiter works properly for this type of application ...it kills sonics ...but at least it does it carefully the abilty to drive low loads is very lilte cooling is done with external heat sinks only ..bearly enough pcbs inside are boiling if stressed generally a marginal design ... capacitance is fairly low for this amp .... at least it has a brand name and a low prize thermal stress produce soldering issues ...resistors driver and protector was blown replaced and go ...
#43 |
Designing my own PCB, can I do business on P3A? Like making complete systems and sell?
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA |
#44 |
i dont see the reason to ask me ...i am not the desiger of the P3A .... you may ask the designer directly for that
www.sound.westhost.com
#45 | |
Did it Himself
Thank you for the description as it is useful to know. I know a lot of people who think the EP500 is some kind of wonder amp, but you have revealed it's true colours and some that I suspected for a long time.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#46 |
![]() ![]() Greek warrior is ready for combat.heheheheh. regards, Carlos
Audiophoolery; http://www.youtube.com/watch?v=m7ERMu825m4; Dx Super Etching; http://www.youtube.com/watch?v=WED3Bvmxepk Last edited by destroyer X; 6th May 2010 at 09:05 PM. |
#47 | |
thanks richie00boy.... compaired that i have repaired almost 600 amps the latest 5 years and only one ( 1) behringer i wouldnt know ... but i will look in to it since i am not really sure for it thanks though
#48 | |
alesis features normal trafo- behringer is torodial alesis features 2X10.000 mfd for the all amplifier one bridge and powersupply behringer features 2x10.000 mfd +seperated rectifier per board behringer features 2 leyer pxb while alesis features piggy boards to fit everything in a 3U short box behringer uses 2U box that is more dee than alesis true the front side is probably made by the same designer regards sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr Last edited by sakis; 7th May 2010 at 03:38 PM. |
#49 |
i am not in tha Class A thingy ...i am just a classic 2SA1302 class AB person ...but bussines is bussines and i have to repair that also from time to time as we speak my first krell is on the way ....
ok doki the machine comes in with a number of problems but most that the amplifier shut down out of the blue for no reason and as the costumer said it just happend after the amplifier has been upgraded from another technician .... striping down the litle brit is not an easy task since to be able to have acces down under you need to unscrew everything and that of course means that you need to redo all the mechano work replace or alline insulators whixh happens to be plenty ... To make long story shorter the amplifier has been upgraded by some tech guy that replace the cables from the pcb to the binding post ( about 20 cm ) from the original cable with VDH cables and beefed the idle enough to boil all the solderings inside the amplifier Results local regulators for the first stage of the amplifier totaly disoldered and afew resistors boiled but other than that no other problems after that discovered some factory mistake ...in chanel A source resistors was 0.33R while in the other channel it was 0.22r replaced the broken , did the soldering and the mechano and then bias the amplifier to something more earthy and listen to it .... terrible expirience .... the sound was "mufled " treble was confusing midle was perfect , bass, sound stage and depth was simply upsent ...just wasnt there ...the amplifier had a terrible low end and seemed to me that was working with some compressor behind it i simply didnt bother to look why costumer was more than happy and that was the end of story ...if anybody bothers to ask if i find the sound of a P3A better i will answer +10.000 times better by far here is some pictures of the litle cr@@p
#50 |
nice simple luxman come in to the shop for service a classic story ...no damages ...all caps to be replaced... a bit if mechano since all was dryied up arround the transitors ... tune the idle and good to go
a bit of cleaning here and there and other than that absolutelly nothing else... I have seen wonderfull production luxman thatsounded superior but this one wasnt one of them .... low power , but better ends ( even better from my previous post ) the amplifier had plent of high and a nice pre amp but wasnt clean enough ... expected from the prize tag of this model ... i think that it was a cheapy on the negative i will say that there is no real protection and luxman in order to avoid power on off noises switches the speakers on off with the same switch that powers on of the all machine ...very cheap i think on the other hand a bellow average amplifier can serve a kitchen system ... here is a picture
| Decent table saw | valleyman | Equipment & Tools | 4 | 3rd May 2008 10:48 PM |
| 10" Sub Comparsion | 69stingray | Subwoofers | 3 | 9th February 2006 10:39 PM |
| Forgot to do this long long time ago | chris ma | Introductions | 2 | 30th October 2003 10:53 PM |
| Long output lead or long output transistors leads? which one to pick? | chris ma | Everything Else | 3 | 6th June 2003 12:06 PM |
| Comparsion of LT1962, ADP3338, REG104 regulator | chengtaw | Solid State | 1 | 3rd December 2002 01:36 AM |
