P3A Comparison table ( long .... ) - Page 42 - diyAudio
Old 19th October 2013, 12:33 PM   #411
thimios is offline thimios  Greece
Default P3A
Originally Posted by AndrewT View Post
You have a 2channel scope.
Show both the input trace and the output trace.
Ok sr.
Here are in-out scopes.
first group.
Upper waveform is output.
Old 19th October 2013, 12:39 PM   #412
Default P3A
Second group.
Waveforms superimposed.
Old 19th October 2013, 01:32 PM   #413
ashok's Avatar
Your generator should have had flat topped square waves ! They aren't so at LF. Should have been a perfect square. Try the generator loaded only with the scope probes at 20 Hz and see if you get a perfect square. If so ,then load it with the amp and see what happens. In both cases scope should be looking at the input signal.You need to get to the bottom of this!
By the way, skip the sine waves. We don't need to see them now. You need to look at only one or two square wave frequencies. Maybe 20 Hz or 50 Hz and 100 Hz. You are only trying to solve the issue of the LF rolloff.
AM
Old 19th October 2013, 01:52 PM   #414
AndrewT is online now AndrewT  Scotland
post412
pics 2 to 4:
are the input and output on top of each other?
In pic 1 is the lower the input (nearly flat)? and the upper the output (LF roll-off)?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th October 2013, 02:41 PM   #415
Bigun is offline Bigun  Canada
Bigun's Avatar
Scope probes can distort square waves - they have a resistor/capacitor divider network inside and usually they have a small adjustment screw so you can balance things out. This is why the scope has a square wave generator. It would be best to check the square wave with a simple direct piece of wire from the generator to scope input.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 19th October 2013, 04:44 PM   #416
post412
pics 2 to 4:
Yes all pictures in post #412 shown input and output on top of each other,except picture 1.
Old 19th October 2013, 05:09 PM   #417
Default P3A
Sure but i have adjust this trimer as required.
Scoping direct on generators output(with the same probe) square wave is flat.
This time i have examine many amplifiers.
I can't see any of them with flat square wave in these low frequencies.
Then i take care to increase the value of input capacitor.
22uf is the required value to came 22Hz flat.
The problem is that never i have seen this big value capacitor in commercial amplifiers.
Old 20th October 2013, 07:11 AM   #418
I think that this little LF anomaly is direct consequence of bootstraped VAS. It is not unexpected and is not a reason for panic. Read Elliott article about Curren sources, sinks, etc., part about bootstrap ccs. In fact, it could be the reason for good subjective impression that P3A makes.
Old 20th October 2013, 07:55 AM   #419
Oops! May be I am wrong. I found Motorola application note AN485 and there is square wave response for 50Hz, 1kHz and 10kHz. 50Hz square wave has the same falling top as thimios's P3A while 1kHz and 10kHz are level. AN485 has active VAS ccs and 10uF input cap, so it seems that falling top line on the square wave amp output is caused by some other mechanism.
Fortunately there will never be any music signal resembling 50Hz square wave.
Old 20th October 2013, 12:33 PM   #420
Bigun's Avatar
I can't say I've ever tested an amp with a square wave at such low frequencies so I don't know if it is a problem or not. I tend to use the square wave from my scope because it's so clean whereas my variable frequency signal generator is not that great but does let me measure gain as a function of frequency. Once I did use a square wave at 20KHz and it fried the amplifier. I read a bit about the stupidity of what I did and that there may be little value in testing at such high frequencies with square waves so I don't do that anymore. From what you are saying, it sounds like it is not a problem. Does the amplifier sound good - yes? - then there's no problem
passive crossover for table tuba long style duder1982 Subwoofers 3 11th August 2013 04:11 PM
How long is long enough to test an amp after repair? spooney Car Audio 2 31st January 2011 12:05 AM
is there a speaker driver comparison table? Pbassred Multi-Way 3 28th November 2004 07:00 PM
Forgot to do this long long time ago chris ma Introductions 2 30th October 2003 10:53 PM
Elliot P3A amp price and comparison Al Garay Solid State 12 1st December 2002 08:07 PM
Copyright 1999-2017 diyAudio
