P3A Comparison table  ( long .... )
Old 8th April 2010, 08:01 PM   #11
east electronics is offline east electronics  Greece
east electronics's Avatar
Default service SAE A201 and P101
here some more just finished yesterday
its the A201 and the P101 from SAE ...
the ampifier needed a 110/230 conversion new trafo 600 W fitted inside most electrolytics replaced retuned idle and working just fine ...
as an ampifier and next to my set it seemed that the amplifier had less bandwidth than my set ...low ends was kinda limmited still clea and not that punchy but seemed to be a lack at the very low stages just about the same for high i got the feeling that wasnt that clean and kind of hissy or harshy trebles
original bias seemd also low but i didnt want to play anything other than the oiginal values ... the topology outputs and configurations reminds the 555 series from Adcom only adcom was by far better
preampifier was a box full of TTL and 80 electrolytics that all refused to work ...replace them all things got a lot better ...
as a buffer and a preampifier is exeptional ( let us not forget its an 1981 design ) it seems that there is no ability to drive long cables or anything that is just a bit capacitive with this preamp
even though there a load of ttl inside to perform all button controls the unit is very quiet and the phonh stage is amazing ...( the costuemr will not run it with a phono ...still the phono stage was tested and seemed to have amazing tollerance to various heads tested i dsay that was extremelly adoptive
id say that both amp and preamp are above average and nothing too amazing
here is a picture
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 8th April 2010, 08:25 PM   #12
Telstar is offline Telstar  Italy
Originally Posted by sakis View Post
i am not willing to give away at any prize anything that is original and has a tag 1302-3281 on ( i have original toshibas also ) totally i have arround 120 pairs more and i am going to use them to construct amplifiers for my own pleasure ....in the coming years i hope to live long enough to construct 100 amps ( more )
sniff
maybe you'll sell me a built amp one day?
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 8th April 2010, 08:28 PM   #13
Originally Posted by Telstar View Post
sniff
sure why not !!!! you can e mail me with full data name and so on an i will include you in my will ha ha ha ha ha ....
beyond jokes ...constract one on your own you will have all my help !!!!
Old 8th April 2010, 08:38 PM   #14
ygpm.
Old 27th April 2010, 11:24 AM   #15
Default a P3A for my son's bedroom ....
almost 1.5 year ago i have constructed a P3A for my wife so i wanted to see the effect of the sound while she was having the baby ... and then use the same system for the baby after it was born ...
The baby loves the sound ( i think ) so is my wife .... the problem was that the amplifier i builted was too big ...the amazing waf factor ... so i was asked to bulit some other version probably less power but for sure less size
here we go ..there some pictures of my new built ... but i have a small issue ...
that is a standard built uses original 1302+3281 in the out ,100pf silvermica for miller VAS and then 100 pf multileyer for the down driver ...other than that everything else is as seen on schematic
i ve been building in the past mostly with bd 139-140 and mJ15030-31 families
this time i used bd 829-830 i had some of them available and willing to try
i wasnt expecting a noticable diference but even though the bias is quiet low since size of the box and heatsink i didnt want to create high temperature inside still it plays by far better than the 139-140 or 15030-31
can anyone explain why ????
can any one double check this and provide an opinion ???
thanks sakis
Old 27th April 2010, 12:33 PM   #16
currentflow is offline currentflow  United Kingdom
Hi Sakis
The main difference between the BD829 and BD139/MJE15030 is the fT. The BD829 has a transition frequency of typically 250MHz, as opposed to 8MHz for a BD139.
It may be the higher speed of these devices which accounts for the sound difference. In what way would you say they sound better?
Steve
Old 27th April 2010, 01:02 PM   #17
well as i describe my approach for this amplifier and some time compared with the DX amplifier which i find very accurate and very precise my amplifier is a bit endy ....means that will represent with problems any signal at the ends ...low and high
now if you see the one that is made with BD139 series and the other was made with BD829-830 seems that everything is more bass is even more rich midle is more perfect but most of all seems that high are by far more clean and have a class A sweetness ...tybe style sound
the previous version i was listening to was biassed at 120 ma per board now this one is biassed almost to 1/4 of this bias and still plays better ...
i have to investigate this farther ...it seems that these driver rock !!!!
( hei do you like my enclosure ??? )
Old 27th April 2010, 02:50 PM   #18
Hi Sakis,
That's an attractive case and I especially like the texture of the front panel
Have you tried comparing your amplifiers' performance with an oscilloscope - possibly by examining the step response?
Steve
Old 27th April 2010, 02:59 PM   #19
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Hey Sakis, thats interesting, any chance you will show a schematic
sometimes we know very little, and sometimes we know too much
Old 27th April 2010, 03:47 PM   #20
will make farther testings ... but you knoe since schematic pcb and all that has been tested a million times mostly i check for offset idle and off we go ...
will do though
tinitus ...the thread is called the P3A comparsion table ....
P3A Comparison table  ( long .... )Hide this!Advertise here!
passive crossover for table tuba long style duder1982 Subwoofers 3 11th August 2013 05:11 PM
How long is long enough to test an amp after repair? spooney Car Audio 2 31st January 2011 01:05 AM
is there a speaker driver comparison table? Pbassred Multi-Way 3 28th November 2004 08:00 PM
Forgot to do this long long time ago chris ma Introductions 2 30th October 2003 11:53 PM
Elliot P3A amp price and comparison Al Garay Solid State 12 1st December 2002 09:07 PM
Copyright ©1999-2017 diyAudio
