Hello!
Here's my idea for an amplifier without overall NFB. Output power is about 35W @ 8 ohm. Output stage is Hawksford E.C. topology. VAS has a diamond structure. DC servo circuit is taken from here. Simulation results are promising. Any suggestions are welcome! |
#2 |
Looks very interesting. Is this to be operated in Class AB ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#3 |
Yes. Quiescent current is 50mA.
#4 |
A tour de force, no less.....
Have you built it, npnp? Does it sound sensational? |
#5 |
#6 |
#7 |
What's the current in VAS stage? I think you could reduce it while kepping the same gain.
Overally a nice schematic with a terribly overengineered servo
#8 |
I made similar input (voltage amplifier) and it sounded lot better with 6dB feedback (taken from the VAS output) then with zero feedback...
Also tried (open loop) mosfet error-correction output stage but it can`t come near bipolar "simple" triple EF.
#9 | ||
Q5, Q19 - 2.5mA Q9, Q16 - 7mA (to work permanently in class A mode) |
#10 | |
![]() THD decreased twice! Thanks! |
| Calculating Zout for Pentode amp with NFB? | Jeb-D. | Tubes / Valves | 32 | 26th May 2012 01:48 PM |
| Source/emitter global NFB amp | jcarr | Solid State | 48 | 19th December 2008 08:22 PM |
| looking for pp amp schematic without nfb | robertc | Tubes / Valves | 62 | 1st December 2006 02:09 PM |
| Amp NFB network - can be used as crossover for bi-amp ? | gene57 | Solid State | 17 | 1st July 2004 10:20 PM |
| Page generated in 0.12015 seconds (77.70% PHP - 22.30% MySQL) with 11 queries |
