Tube/Mosfet 100W Hybrid Amplifier
Old 18th April 2010, 12:15 AM   #11
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
I'm not interested about best figure, can be better with BJT, but people just want tube/mosfet hibryd amplifier, and I don't want argue about that. Tube or SS also is not a question. Simple give people what they want.
Old 18th April 2010, 12:25 AM   #12
apexaudio's Avatar
Originally Posted by nigelwright7557 View Post
A simple way to do it is to take an SRPP valve front end and ac couple it to a classs AB MOSFET amplifier.
That is not hibryd. I have output stage in post #5, just not sure for VAS. SRPP is option.
Old 18th April 2010, 12:59 AM   #13
Gordy is offline Gordy  United Kingdom
This is just my theory...
Keep VAS simple, just a single tube...
Consider a triode connected 7788 (E810F)... load the anode with constant current source about 20 mA; will have a gain of approximately 50 with a reasonably low internal impedance (I do not have my note book here, but remember impedance as about 2 K Ohm, maybe lower).
Then AC (i.e. capacitor) couple it to your output stage.
Old 18th April 2010, 01:13 AM   #14
apexaudio's Avatar
ECC88 is priority, I already have about 200 pieces.
Old 18th April 2010, 01:54 AM   #15
Yes, that does change things!
Well, ECC88 has nice characteristics, so a simple common-cathode amplifier should get you what you want. I would estimate using a CCS anode load of 15mA, a -2V bias point, and 110V on the anode. However the output impedance of the stage might be reasonably high at about 2700 - 3000 Ohms. Maybe that is OK for your circuit, or maybe you might need a source follower between tube and output stage.
For info, if you have not seen them, Mr Wim de Haan shows some hybrids here: Wim's DIY Audio Projects
Old 18th April 2010, 06:10 AM   #16
apexaudio's Avatar
Thank's for info,
Old 18th April 2010, 10:04 AM   #17
apexaudio's Avatar
HT100 with VAS
Old 18th April 2010, 04:06 PM   #18
Rikard Nilsson is offline Rikard Nilsson  Sweden
Originally Posted by qsa View Post
I mean IRFP240/9240 are not really complementary devices, it sound horribile in mosfet amp...... BJT Design Sound better compare to IRFP240/9240
we have test it in Mosfet amp and in my opinion IRFP240/9240 is no go in mosfet amp
In what way do they sound bad? How does it show on measurements?
I have always found tube/semiconductor amps kind of strange, or at least the reasons people wnat them. Hybrids are a sure way of getting the downside from both tubes and transistors at the same time......
Old 18th April 2010, 04:42 PM   #19
apexaudio's Avatar
People who want hybrid amplifier think that useing tubes and mosfets getting the best from both worlds at the same time.
Old 18th April 2010, 04:54 PM   #20
Yes, I know. And I think just the opposite. Probably just me thatīs odd actually.
Tube/Mosfet 100W Hybrid AmplifierHide this!Advertise here!
Maplin 100W mosfet amplifier - power supply problem HBrunt Solid State 32 3rd December 2013 07:11 AM
MOSKIDO - Hybrid Tube/MOSFET Amplifier Kashmire Pass Labs 7 22nd September 2011 08:30 PM
Hybrid Tube / Mosfet Amplifier poynton Tubes / Valves 8 10th August 2007 05:32 PM
