Symetrical schematics are alike plague in Brazil, do you like them? - Page 16 - diyAudio
Old 1st July 2010, 02:53 PM   #151
sumaudioguy's Avatar
Most of the limiters seen here on DIY are peak current only no matter the output. These I call "the always fail blow up the amplifier" circuit and are truly worse than nothing at all. The Leech amp limits current to a small value when the output voltage is small and increases current capacity as output voltage becomes larger up to the peak current. This loosely tracks the SOA of the transistors, well enough to protect output from ever blowing from over current. So there is the minimum current which is always allowed, the slope with the relationship between output voltage and output current, and then there is the peak current limit which the output voltage is above a certain value.
So possibly I got the name wrong but above is how it works. Please give it a proper name if you like.
What the other guy said----Standing on the shoulders of giants.
New avatar- no more little array
Old 1st July 2010, 03:09 PM   #152
AndrewT is online now AndrewT  Scotland
Leach discusses his limiter in his Lo Tim paper.
The graph clearly shows a horizontal slope and an inclined slope.
Both of these slopes are controlled by the voltage drop across the emitter resistor.
The resistor to turn this current limiter into a VI limiter must enable monitoring of Vce. One extra resistor gives a VI limiter.
Jens incorporated the extra resistor in his Leach clone PCBs for a true VI limiting action.
I equate SOA limiting to VI limiting in this respect. This is due to the very important Vce dependance for any of the current/power limits implied by the SOA.
regards Andrew T.
Sent from my desktop computer using a keyboard
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 11:19 PM
Sale: Some fostex's and alike Piek Swap Meet 0 21st July 2008 01:17 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 09:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 02:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 11:27 PM
Copyright 1999-2017 diyAudio
