Symetrical schematics are alike plague in Brazil, do you like them? Symetrical schematics are alike plague in Brazil, do you like them? - Page 2 - diyAudio
Old 6th April 2010, 04:04 PM   #11
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Thank you folks...all comments readed, and will take a look at the schematic
Yeah...schematic is reversed..but the simulation schematic seems good..at least current is ballanced, also voltage and small off set.... output waveform good enougth.
Girls.... that's what we like...cannot post too much...only electronic girls...or audio electronic stuff.
regards,
Carlos
Old 6th April 2010, 04:04 PM   #12
wahab is offline wahab  Algeria
These kind of amplifiers, when correctly implemented are
way better than doug self s so called blameless.
I published such a design that you eagerly criticised
since it seems that you didn t manage to make a single one
work well enough, so you branded the amp bad rather than
asking yourself some questions about your ability to implement
such a design, prove is that you didn t use a single technical
argument to prove your point.
awb50 ,a simple power amp
Contrary to a single differential that will be very tolerant
of mistakes and will still work relatively fine, a symetrical
differential , although very simple , ask for a little more
skills to produce the good resuts..
Old 6th April 2010, 04:07 PM   #13
Default I see Wahab... 50 years building was not enougth
needing more skills...well... i have only to call Wahab!
You built that one Wahab..and have not build Blameless...or the opposite...and was enougth to conclude..what a brain man..you know..when i grow up i wish i will be alike you.
Man... when you met this man you use to talk... i think you do not even know him.... the man..Mr. Skill, give him my regards... and also my complains..as he is present in more modern guys when was not with us..the old folks..the veterans.
heheheh
regards,
Carlos
Old 6th April 2010, 04:15 PM   #14
the complementary LTP input stage is similar to what Leach has used.
But the rest is completely different.
No Cascode
Dual output from both LTPs
Dual output driving a folded Cascode.
Drivers as VAS
No triple EF (Locanthi T).
Global over full frequency instead of LF feedback
No HF feedback loop excluding last stage.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 6th April 2010, 04:24 PM   #15
Carlos
I did build a blameless well before Doug Self highjacked
the idea and used it as his typical design...
I wasn t even an adult at the time.
Anyway, if you need some explanations about the
subtilities of the symetrical siblings, will be a pleasure
to give some explanations..
Andy_c , who is infortunately no longer by there
did some smulations to compare the blameless to
a symetrical differential, and did found that doug
self prefered design was better, prompting many by
there to applause the technical comparison that were
in fact badly flawed in the behalf of the blameless.;
I did recheck the comparisons, and it appears that the
symetrical differential is better even if it use less
negative feedback..
Old 6th April 2010, 04:48 PM   #16
Default Highjacked?.... really?... Doctor Self did that?
heheheh.... maybe you are kidding.
Slone made a Blameless..do not know if he made in advance compared Doctor Self..or the opposite... in the reality...in our modern world, it is very difficult to find the ones have really created something new...maybe Dunlap....but even his design, others may say was not him.
Well..it is not impossible two persons, different places and same time to have the same idea.... things are intuitive and some evolution are obvious.... alike some consequence...if installed CCS to the differential..then why not to the VAS, to the Drivers and so on?.
First stage differential....why not the second stage too?...so... consequences, obvious developments..when one is publishing the differential, other was creating the differential VAS.
But for sure you are skilled..... a good engineer Wahab...there are the Practice Skill...the theoricall Skill and the ones have both.... there are the one have scientific approach and the Imaginators.. as "they think".... they have a lot of opinions..some of them have never touched a soldering iro..have never compared anything....but they think a lot.
You are good.... fast you have found that 220 would be the best value to the my amplifier, the first Vas emitter load.... you realise very fast...because good theorical or practice skills, or even both of them.
It is interesting to know what people "think" about that...but also, would be more interesting to know and to listen, the ones made the complete job... the ones have analised the schematic, the ones have calculated, have simulated, have assembled, have listened and have compared the way i did..... this way..i will know thougths from another one that had the same kind of experiences compared the ones i had.
I remember 5 amplifiers, in the reality five variations around the same schematic..as Marshall Leach has two main models and these ones i am talking about are sligtly different.... my people have supressed something...reduced, simplified a little...in the reality...i have not registration of all i have made..but for sure more than 60 amplifiers with double symetrical input i have assembled, and listened, and compared.
Much more than 5000 units made.... now a days i am super lazy, doing 3 or 4 a week (200 per year or less)...but was not so slow this way...around 1.7 each day was the average.... then calculate what this means in 50 years.... i am thinking in 5000 thousand..but calculating you see that can be much more than that....6 times more.
And always i found this one not good....always i found the boostrap ones much better..also the ones with chips not very good, and the ones with EF sounding better.
Well.... people alike you Wahab, that is a little bit old and have build hundreds and thousands can say something...so...i respect that you say it can be even best than Blameless... sadly, my years of research cannot confirm what you said...so..there's something strange on that.
regards,
Carlos
Old 6th April 2010, 06:03 PM   #17
Default So many multiple repeated times i have realised one amplifier was not all that good
while comparing..when before i was satisfied with that beated amplifier, that i feel strange when i perceive that there are folks with golden ears or super powers that can discover that without listen, and without compare.
I have learned, and that is the most absolute truth that is now a days the north of my life...that we do not know how good is an amplifier before compare it with others.
We may think, we may imagine, we may believe...but we really do not know..TILL we make comparison.
We have troubles to say about the best..... as we need to refer to others..best compare to what one? is the question that comes imediatelly...so.... all is a result of comparison..good, better, best, worse...all this is relative, and depends two things..the one is better and the one is not the best.
My amplifier is the world best considering all i could listen, all i could buy, or build....but of course..may exist one or much more than that able to beat it.... i had not that chance to listen
I do all i can..people present schematics and i run to build and to test...but i know that some folks do not build, do not listen and go spreading "I think so" all around.
When people use "i think so"...turn to myself i suspection person that do not think with precision... imaginative and biased..without practice and testing of his own theories and beliefs.
regards,
Carlos
Old 6th April 2010, 06:21 PM   #18
PMA is offline PMA  Europe
PMA's Avatar
Eloquent, if I stay polite.
Old 6th April 2010, 06:23 PM   #19
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
After 50 years building I'm sure you have very good building abilities (at least for building amplifiers in the way they were 25 years ago, because you seem to completely reject all the progress made in the last 25 years )
Creativity and open scientific mind are different abilities. You can build amplifiers for 50 years without developing them. In fact I think you lack both, and it's probably too late in your life to develop them.
I have not been doing anything for 50 years because I'm way younger. However, after 4 years learning class D by myself now I'm the designer of one of the smallest, lightest, most efficient, most cost effective and most powerful subwoofer plate amplifiers currently in the professional audio market. It's (conservatively) rated 4000W @ 2 ohms with greater than 90% efficiency and only 7lbs weight (including heatsink, faceplate and DSP).
This claim is not as eloquent as yours, it's much harder to reject.
Be creative. Make real achievements.
I use to feel like the small child in The Emperor's New Clothes tale
Old 6th April 2010, 07:07 PM   #20
east electronics is offline east electronics  Greece
east electronics's Avatar
with respect to all previous posters and to you my friend uncle charly ...
it is often that we miss the obvious
which in this case is simply that this is probably a bad or simplified copy of some chinese amplifier that actually works or worked in the first place ...after its been allready a bad copy which probably bad copy means that either schematic or parts are now canibalized compared to the original schematic you are simply watching the results ...
Eva most of the times i agree and respect your technical skills ...in this life i will probably never achieve such an approach ...BUT i disagree about the evolution ...even a dynaco amplifier can be evolved to something better ...better parts ..better pcb ....better topology but yet again same idea and nothing inovative ... that is very true ...
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Symetrical schematics are alike plague in Brazil, do you like them?Hide this!Advertise here!
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
Sale: Some fostex's and alike Piek Swap Meet 0 21st July 2008 12:17 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright 1999-2017 diyAudio
