Old 5th April 2010, 01:47 PM   #1
Audio Junkie
Zero Cool's Avatar
Default Trafo CT connection point
I am working on an amplifier that has the transformer CT connected in an unusual way. this amp has a separate PCB for the PSU caps that connect to the amp PCB.
Normally i would expect the CT to be connected to the center point of the power supply caps. Instead this amp has the CT connected to the amp board ground point and then has a wire that connects from that point to the Cap board. and the speaker ground is taken from the other end of the ground trace on the amp board as well. this doesn't seem like the best method.
Correct me if I am wrong but wouldn't it be an improvement if i connected the transformer CT and the speaker ground directly to the center point of the cap board and then ran a wire from that point to the amp board main ground point??
Zc
Old 6th April 2010, 01:21 PM   #2
Audio Junkie
Zero Cool's Avatar
BTW this is NOT a rail swinger type amp.
Beginner Q: any ct trafo for Stax adapter? pilli Parts 1 20th February 2008 03:57 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
Benifits of point to point wiring for digital circuit? MGH Digital Source 15 14th September 2006 10:17 PM
Anyone use magnet wire for point to point wiring projects? Hybrid fourdoor Parts 10 2nd February 2004 08:11 AM
Page generated in 0.07014 seconds (77.58% PHP - 22.42% MySQL) with 10 queries
