hello Dear Friends,
this is the Tina 7 T.I. simulation of the Kuroda TL071 60W FET Amp published in September 1982. More info here : poweramp The attached .zip contains the schematic ready for simulation. Cheers, Steph |
#2 |
hello Dear Friends,
this is the LTspiceIV simulation of the Kuroda TL071 60W FET Amp published in September 1982. More info here : poweramp The attached .zip contains the schematic ready for simulation. Cheers, Steph |
#3 |
hi,
helmutsennwald and analogspiceman helped me for improving the .TRAN directives, in order to get a high-resolution FFT plot under LTspiceIV Waveform Viewer, with a noise floor of -180dB, quite a spectacular performance. I wanted a FFT look and feel equal or better than what we get using spectrum analyzers like B&K and AudioPrecision. In order to get sharp spectrum lines, a frequency resolution of 10Hz got chosen, translating into a 100ms analysis window. 1 - In order to decrease the physical noise floor, one must allow the circuit to settle, and this is of big importance if spice had trouble (which is nearly always the case) finding the DC operating point. Failure to do this generates a physical -120dB noise floor. The .TRAN directive must thus become something like .TRAN 0 101ms 1ms for allowing spice to gently deal with the circuit during 1ms, before storing the next points that will be used for a 100ms FFT. 2 - One must force spice to generate all the points that the FFT will need, without interpolating some portions of the signal. This is done by adding a 4th parameter to the .TRAN job : the max step, which is chosen equal to 1 microsecond. Is this 4th parameter equal to a separate option "maxstep = 1u" ? 3 - One must force spice to refine each point, considering that a point gets properly done with a tolerance of only 1e-6 during the iterative matrix solving process. This is done with the option "reltol=1e-6". 4 - One must de-activate the waveform compression spice is using by default after completing the .TRAN job. The de-activation of the waveform compression is done by the option "plotwinsize = 0" 5 - One must ask spice to use double-precision arithmetics. This is done by the option "numdgt = 15". Actually, the LTspiceIV UserManual manual says that any parameter greater than 6 activates double precision arithmetics. 6 - The FFT processor must be configured for high resolution. This is done by asking a 4Meg points FFT, without windowing. see http://tech.groups.yahoo.com/group/LTspice/messages and enter "FFT after .TRAN" in the search box The results are self explaining (see the pictures). Use the .zip if you want to run the FFT plot. Quite worrying is that the "old fasion" .FOUR says now that the distorsion is very low. I let you discover the spice log : **** Circuit: * C:\LTspice Simulations\Kuroda TL071 60W FET Amp (1982)\Kuroda TL071 60W FET amp (1982) - with improved .TRAN directives.asc Early termination of direct N-R iteration. Direct Newton iteration failed to find .op point. (Use ".option noopiter" to skip.) Starting Gmin stepping Gmin = 10 Gmin = 1.07374 Gmin = 0.115292 Gmin = 0.0123794 Gmin = 0.00132923 Gmin = 0.000142725 Gmin = 1.5325e-005 vernier = 0.5 vernier = 0.25 vernier = 0.125 Gmin = 5.90244e-006 vernier = 0.0625 vernier = 0.03125 vernier = 0.015625 vernier = 0.0078125 Gmin = 5.93519e-006 vernier = 0.00390625 vernier = 0.00195313 vernier = 0.000976563 vernier = 0.000488281 Gmin = 5.9417e-006 Gmin = 0 Gmin stepping failed Starting source stepping with srcstepmethod=0 Source Step = 3.0303% Source Step = 25.7576% Starting source stepping with srcstepmethod=1 Source Step = 3.0303% Source Step = 25.7576% Source Step = 26.1245% Source stepping failed Trouble finding operating point....skipping operating point for Transient analysis. Heightened Def Con from 1e-011 to 3.701e-008 Fourier components of V(vout) DC component:-0.000817022 Harmonic Frequency Fourier Normalized Phase Normalized Number [Hz] Component Component [degree] Phase [deg] 1 1.000e+03 2.252e+01 1.000e+00 -0.27° 0.00° 2 2.000e+03 6.171e-05 2.741e-06 6.73° 7.00° 3 3.000e+03 3.344e-05 1.485e-06 83.83° 84.10° 4 4.000e+03 5.249e-06 2.331e-07 -141.12° -140.85° 5 5.000e+03 5.222e-06 2.319e-07 -24.32° -24.05° 6 6.000e+03 3.983e-06 1.769e-07 -120.34° -120.07° 7 7.000e+03 5.265e-06 2.338e-07 -8.37° -8.10° 8 8.000e+03 5.038e-06 2.237e-07 -131.99° -131.72° 9 9.000e+03 5.909e-06 2.624e-07 -9.36° -9.09° Total Harmonic Distortion: 0.000317% Date: Tue Apr 06 02:26:47 2010 Total elapsed time: 34.250 seconds. tnom = 27 temp = 27 method = modified trap totiter = 456927 traniter = 450738 tranpoints = 130564 accept = 124155 rejected = 6410 matrix size = 132 fillins = 302 solver = Normal Thread vector: 38.5/26.4[2] 16.6/11.7[2] 6.0/5.2[2] 5.5/4.5[2] 2592/500 Matrix Compiler1: 30,4 Ko object code size 17.6/12.9/[7.4] Matrix Compiler2: 17,2 Ko object code size 8.4/9.6/[4.7] **** This means that all my former considerations about distorsion may need to be reassessed. However, I doubt that a TL071-based amp, can have a distorsion as low as 0.000317%. Formerly, not using hig-res .TRAN directives, the displayed distorsion by the non hi-res .TRAN directives was 0.017%. And I found this to be a realistic and reliable figure. So, where is the truth ? Hi-res .TRAN or no hi-res .TRAN ? Cheers, Steph |
#4 |
Unfortunately, I don't have the original article on hand (I can check it when I go back to Japan next time, though), but 0.017% sounds more reasonable for this topology.
By the way, as I understand the reason you are studying this topology is to avoid either obtaining dual JFETs or matching singles. JFET like 2SK30A (GR) is cheap enough to pile up (way cheaper than output devices) and the result would be satisfying after matching them with small effort and time. I believe it's worth a consideration. Best regards, Satoru |
#5 |
My simulator says that this circuit doesn t work...
Output DC operating point is at +36V with the components values displayed in this schematic. Did i miss something ?... |
#6 |
What simulator ? What schematic ? What TL071 implementation ? Pls attach your spice log, and I'll see what I can do for you.
#7 | |
So now, I am concentrating on this particular topology, willing to understand it in detail, willing to see what are the followups. There is one notorious followup, described in the application information of the Analog Device SSM-2131 opamp (previously made by PMI). The followup can be found as Figure 6 on page 7-86 of the AD/PMI Analog Integrated Circuits Data Book Vol #10 Copyright 1990. If somebody could provide a .pdf of this, that would be very helpful. COLBY got inspired by the AD/PMI SSM-2131 arrangement. He designed a power amp. It is here : members.aon.at/viellieb/amps/pics/amps/cfbamp.pdf See attached.pdf. I think there is a clear future for power amps using audio opamps as front-ends, especially if it can be proven that the opamp is working within his nominal enveloppe (gain, load, frequency range), bringing thus his tonal signature in a smooth way. Kind of design philosophy for the future. Use the audio opamp of your choice in your power amp. With the advent of Class-D amps, it is needed to find new arguments in favour of Class AB amps. It is thus needed to get the Class AB amps incorporating the latest silicon advances like ultra low noise, ultra low offset, laser-trimmed font-ends. You will only get this if you are relying on an opamp as front-end. My understanding is that the Kuroda is a solid, simple, efficient building block, that may be used "as is", or in more complicated arrangements like : - The "Quad 405 Bridge" in pure Class B like the original, but also in Class AB - Technics "Class AA bridge" in full Class A like the original, but also in a Class A voltage amp + Class AB current amp - The "Soft Non-Switching Class AB", a new Class AB sub-class, now working on simulation The use of SMDs may allow PCBs as compact as the ones used with TDA7293 or LM3886. The advent of lateral NMOS + PMOS in a single TO-247-5L package (Magnatec Alfet) will provide a nice simplification. Now that Magnatec is busy with a 5-terminal TO-247, why not a 7-terminal TO-247 in the future, with 2 pins for thermal management ? I'ts going to be fun again ! Soon, we'll be again in the the golden age of analog amplification ! Time to reopen our files ... It is amazing to see LTspiceIV being able to test and solve things today, that remained untested and unsolved 30 years ago. All we need now, and very urgently, is a "blameless" digital crossover, "blameless" audio DAC and "blameless" volume control, for feeding those next-gen (or next-gem ?) analog amplifiers. Otherwise analog amplification will be defeated by Class-D amps, bitstream-fed ! For sure. And sooner than we may think. Cheers, Steph |
#8 | |
a) presented in the 88th AES convention March 1990, b) explained in the SSM-2131 data sheet, c) re-explained in the AN-211 Analog Device Application Note, d) patented in the US patent #5,097,223 filed May 22nd 1990 and granted Mar 17th 1992. See attached .zip file. Due to file size restrictions, I was unable to attach the AN-211 Analog Device Application Note, but you may find it here : http://www.analog.com/static/importe...17334AN211.pdf What is the Japan patent #37717 dated 4/81 cited on the Alexander patent cover page ? The Kuroda 1982 implementation maybe ? The 88th AES Convention paper may be downloaded here : AES E-Library: A Current-Feedback Audio Power Amplifier Cheers, Steph Last edited by steph_tsf; 7th April 2010 at 12:52 PM. |
#9 |
Hello friends audiophiles,
In 1990, I rode a modified version of Kuroda and added some components and temperature control. It works fine with speakers capacitives and normal LouldSpeaker box. Attached the schematic done in EagleCad. ScanImage006.jpg ScanImage002.jpg |
#10 |
Friends,
New images from Mos_Amplifier TL071. Based version of Kuroda (1982) Hugs.. |
| 6N11+TDA7293 60W+60W Amplifiers | fn9mm | Chip Amps | 5 | 28th August 2011 12:37 PM |
| SLN Pre-Amp - Elektor Aug 1982 | GlidingDutchman | Elektor | 20 | 28th August 2009 12:42 PM |
| cal gamma dac op-amp tl071 | Chilli6565 | Digital Source | 14 | 21st August 2008 10:03 PM |
| HEX-FET 60W/4ohm Amplifier | djdan | Solid State | 47 | 9th January 2006 10:15 AM |
| Page generated in 0.18050 seconds (86.17% PHP - 13.83% MySQL) with 11 queries |
