What does this series cap and resistor do in the differential input stage?
Edit: I meant to add: Sometimes I see it in schematics, and some times I don't. Even with the same manufacturer, but different models. Apparently, it isn't absolutely neccessary. Last edited by Artie; 4th April 2010 at 11:43 AM. |
#2 |
it loads the two halves of the LTP and thus selectively reduces the LTP gain.
Reduced gain is usually used to add phase margin and add gain margin to the amplifier.
regards Andrew T. |
#3 |
Thanks Andrew, although I'm surprised by that answer. (Not doubting you.) I thought that the degeneration resistors did that. That cap/resistor looks more like a high-pass filter.
#4 | |
jd
/Another new issue: Linear Audio Volume 3! |
#5 |
Ah . . . thanks for that clarification. So, let me ask this: would it be considered a "mod", or improvement to add this to a circuit that didn't include it already? Was this something omitted as a cost cutting measure?
#6 | |
is surely instable without it.. If you add this RC circuit to an amp that doesn t need it, it will undoubtly degrade the performances. |
#7 |
Could I impose on you to expand on that a bit? The reason I ask is because I see it more on higher end units than lower. Its generally located between the differential input pair and a current mirror or CCS. Units that omit it also omit the CM or CCS. If I were to mod a unit, I'd do the full monty, (so to speak), with CM or CCS.
#8 |
"High end " units are generaly high power, and as such , they
need more gain to reach full power using a standard input voltage in the vicinity of 1V, so there will be less negative feedback available to reduce distorsion. That, with the high output voltage that ask for more gain/bandwith product, will mandate a higher open loop gain to reach the same perfs as a say 50Wamp. More open loop gain is synonym of more instability issues, therefore these kind of arrangements to reduce the open loop gain at very high frequencies , where the instabilities occur... |
#9 |
there are many places that compensation can be added.
I suspect they all sound a bit different. The trick is finding those that are needed and sound right.
regards Andrew T. |
#10 |
Ok. Thanks again guys. This something I just need to read up on some more. That circuit segment, by the way, is from a Yamaha CA-400. Its a good amp, but not a powerful one.
| How to design input stage with specific input impedance/pot value | mahleriana | Tubes / Valves | 0 | 16th November 2009 09:37 PM |
| Resistor before or after cap? | fatmarley | Multi-Way | 5 | 6th May 2009 04:26 PM |
| current bias j-fet input 2sk170 ,2sj74 at input stage | YUTK | Solid State | 11 | 2nd June 2005 03:34 AM |
| input cap at D1 I/U stage | Klaus | Pass Labs | 3 | 30th December 2003 11:00 AM |
| Resistor-Input vs. Choke-Input vs. Cap.Multip. | Blitz | Pass Labs | 13 | 26th September 2003 04:59 AM |
| Page generated in 0.12200 seconds (79.34% PHP - 20.66% MySQL) with 11 queries |
