I am currently assembling a small pre-amplifier:
![]() consisting of 2 sections: 1) the digital section Heart of the digital section is a µC PIC18F4550 that controls a relais-board (source selection, not shown), accepts remote-control, drives a 2x16 LCD, ... 2) the analog section Consisting of a OPA2132 attenuator and an AD823AN OpAmp. Power consumption is approx. +5 V / 250 mA for the digital section and about +5 V /150 mA and -5 V / 50 mA for the analog section. The PCB has provisions for 2 bridge-rectifiers. Do I really need 2 transformers or can I take one transformer having 2 x 8 VAC / 750 mA secondary windings, one secondary winding to produce the -5 V and the other winding for the digital and analog +5 V rail? Best regards - Rudi Ratlos |
#2 |
I dont see why one transformer wont do the job.
Just keep analog and digital grounds seperate and make sure the supplies are well decoupled.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
Moin Moin Rudi;
One tranformer will probably work, but it's not a good Idea because the analogue and digital grounds should be strictly separated to avoid appearance of clock pulse residuals on the analogue section.('Übersprechen') Regards Arne |
#4 |
Moin Arne,
so I will use 2 transformers indeed. Best regards - Rudi_Ratlos |
#5 | |
There are many docs regarding grounding and two TRANSFORMERS are never mentioned. Just star ground. That means that the power can come from same transformer with 2 windings or even from the same winding if you use RF separation (ferrite beads, coils, capacitors...). One exemple: http://www.analog.com/static/importe...0Grounding.pdf Last edited by SoNic_real_one; 6th April 2010 at 10:41 AM. |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| Back to Back transformers as Isolation transformers | mikee55 | Chip Amps | 2 | 17th March 2006 11:38 AM |
| Transformers | Slawek | Swap Meet | 0 | 3rd November 2004 02:58 AM |
| transformers? | cunningham | Solid State | 18 | 23rd October 2004 07:41 PM |
| Can i use one of these transformers? | Matttcattt | Parts | 5 | 18th September 2003 04:12 PM |
| Page generated in 0.09114 seconds (73.32% PHP - 26.68% MySQL) with 10 queries |
