New Push Pull Buffer Approach for special Kind of THD - MOSFET & BjT - New for me
Old 2nd April 2010, 03:13 PM   #1
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Default New Push Pull Buffer Approach for special Kind of THD - MOSFET & BjT - New for me
Today I get an integrated amplifier for repair. It is a NAD 310. The reason was quickly find: burned PCB and broken solder points arround the zener's for the baxandall equalizer stage.
But curious and new for me is the output power buffer topology:
1) one N-Channel MOSFET in the positive half (Philips/NXP BUK-555, TO-220)
2) one PNP BjT in the negative half (Sanyo 2SB817, TOP-3)
What kind of push pull output buffer is this (so called ?????) ? Who knows more about this, e. g. AES papers and other amplifier models, where such power buffers are in use?
Schematic for NAD-310 you will find here:
Schematic Diagram - Free Schematics Download (highest resolution)
http://img526.imageshack.us/img526/9...d310schxb3.jpg
http://www.diyaudio.com/forums/solid...me-info-2.html
Old 2nd April 2010, 03:43 PM   #2
stoc005 is offline stoc005  United States
stoc005's Avatar
Capacitor coupled to the speaker (UCK!), single supply amplifier. If this is SOTA, I give up. Smells cheaply built to me. No RIAA preamp. I guess vinyl is dead.
Old 2nd April 2010, 04:13 PM   #3
Definitely better than serial relais contact against dc protect, even by use of cheap caps.
in my previous post the schematic URL was wrong:
Nad Download Page - nad-310-integrated-amplifier-schematic.pdf || ABELtronics
Old 2nd April 2010, 07:12 PM   #4
stoc005's Avatar
And exactly what is C225 (33p) and R255 (100K) doing for us?? Why is some of the (high frequency??) left channel, via these two parts, fed back into the right channel input(Q203 emitter)?? Why the cross channel feedback??
Didn't get me wrong, if you are happy with the sound, keep using it. It's just that I suspect there are "better" amplifier out there, IMHO. I listened to a Heathkit AA-15 that had a 'lytic for DC blocking in series with the speaker and was a single supply amp for years. I was happy with it. The NAD circuitry is just not really revolutionary.
Old 3rd April 2010, 02:34 AM   #5
AKSA is offline AKSA  Australia
Tief,
This topology measures badly (high even order), but sounds very good.
A quasi version of this approach is also extant from the same era. N type mosfet at pos rail, pnp driver and npn output at neg rail. This sounds very good, too.
Give it a good listen once you fix it. You will be very surprised.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 4th April 2010, 09:02 AM   #6
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
It is buffered class A with positive feedback. The designer trying to create good buffer with mosfet. The bottom side has linear topology and the upper side just hot resistor. Then buffered, then FB placed, just it, I think.
Old 4th April 2010, 03:49 PM   #7
balaboo is offline balaboo  United States
Like Hugh (Mr.AKSA) said, this is a very musical sounding topology - I use it for my guitar amps, except that I use NPN bjt and IRFP9140. Not too bad for music listening, but fabulous for electric guitar or vocal usage !
And the output capacitor helps prevent blown speakers when playing "live" ...
Old 4th April 2010, 10:04 PM   #8
ontoaba's Avatar
Most positive feedback amplifier has its disadvantage at high frequency, but this is might different because of the buffer has faster and separately follow the stage before. Lower side BJT gaining the current source, and upper mosfet gaining that hot resistor.
It was good in past, but it is not interested any longer because of high THD and hot VA stage.
Old 6th April 2010, 10:15 PM   #9
Originally Posted by AKSA View Post
Tief,
Hugh
Yes, in case of low idle current between 30mA and 100mA (badly measuring results still present, independend of the topology).
If I choice an idle current of 1,3A, this topology measures very good (see attachement - please ignore the device numbers from my schematic because it's not the same than by orig NAD schematic).
onto aban: Where you have discover the PFB (positive feedback) ? I find only a NFB network (negative feedback - consists of 820R/10R/1MF for AC and 3K3 for DC).
stoc005: integrated RIAA head amp by an integrated amp is a very bad solution for various reasons. The royal way is still an external RIAA device like this:
NAD Electronics :: PP-2 Phono Preamplifier
Cheap and high quality at the same time.
Old 7th April 2010, 07:38 AM   #10
ontoaba's Avatar
hi thief, you have improved its simulation result, but 1.3A is about to think another way, it is too hot for cheap amps.
New Push Pull Buffer Approach for special Kind of THD - MOSFET & BjT - New for meHide this!Advertise here!
Zero feedback push-pull buffer : piezo driver idea rjm Solid State 4 2nd April 2013 11:02 AM
BJT Push pull amplifier SOA pizeo driver dareon Solid State 11 18th March 2010 03:06 PM
Unity-Gain EL84 Push-Pull Power Buffer Kashmire Tubes / Valves 9 11th February 2010 03:27 AM
Push-Pull Output Stage MOSFET Tester lineup Solid State 2 11th September 2008 12:00 AM
ecl82/6bm8 push pull special designs Glass_painter Tubes / Valves 1 19th April 2003 07:45 PM
Copyright ©1999-2017 diyAudio
