Speaker delayed insertion, speaker protector, off set sensor
Old 1st April 2010, 11:54 AM   #1
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Speaker delayed insertion, speaker protector, off set sensor
having fuses too.
I found in a book...the board was made and sent me as gift, by Mr. Miguel Malheiros (Rio de Janeiro).
Soon i will assemble, adjust and test...if good...then will describe how it works and will post more details to the ones interested.
This is not a Dx Corporation Design...found in a book.... will inform you, the book name, and page, very soon.
In advance will see how this works.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 1st April 2010, 12:04 PM   #2
Default A friend provided me the PDF, produce the board layout..it is not a Dx design
That friend printed my name on it...but it is not mine...a mistake only.
Here you have layout..also the book schematic and the board schematic.
The book is "Electricity and Electronics, second edition - G. Randy Slone....book page 278
He is the designer, not me!
The book describes how this works...you can see just watching the schematic..but if result fine, then i will explain, describe, myself.
regards,
Carlos
Old 1st April 2010, 12:40 PM   #3
Default I do not know if this will work fine, if there's some error on it or not
seems fine..but maybe some resistance adjustment may be needed, better transistor selection, or to test ours.... timing adjustment and so on.
Seems fine...but who knows?... sometimes we find mistakes...human mistakes or layout mistakes..parts inverted and so on.
I will assemble and will be happy to let you all know.
Soon.
regards,
Carlos
Old 1st April 2010, 02:09 PM   #4
Default I will use BC546....but observe it is inverted related the 2N models
because of that, you should use 2N5401 or 2N5551 to match the board.
I will invert mine BC546 to match the board.
regards,
Carlos
Old 1st April 2010, 02:36 PM   #5
Default In my case i have to go downtown to buy parts.... exclusive travel to buy 1W zener
Not to go there..only because 2N551 and a zener diode...i will make some changes.... also i may use a 7824 voltage regulator instead these three parts modified.
Maybe Q5 will need a bigger transistor there....more safe....maybe a BD135 or BD139 or something alike...or TIP31C, or TIP41C
regards,
Carlos
Old 1st April 2010, 02:48 PM   #6
gaetan8888 is offline gaetan8888  Canada
regards,
Carlos
Hello Carlos
Nice circuit, looking at the 1.jpg image, I remember that Cambridge Audio was using a similar but less developped circuit in the P40 amp.
The transistors Q2 and Q3 act like a flip flop circuit (in french we call that une bascule), wen there is a too big signal at output, Q3 will in a blocked situation and the protection are intering in fonction.
Thank for sharing this circuit.
Bye
Gaetan
Old 1st April 2010, 03:04 PM   #7
Default Not mine dear Gaetan...was Randy Slone the one did it
But you are welcome..your kindness to think i have made this.
I have the text book..they explain the way this works.... wonderfull...if you want i can copy and produce small images to send you Gaetan730...but send me an email..to confirm your adress..as i have changed a lot of things here...formating hard drive, installing older (and better) windows...and i have changed also Browser, now using several others, avoiding Internet Explorer...and because of these things i have made..maybe i have lost your email adress...i think i have..but not sure.
carlos.eugenio1951@yahoo.com
We call here "multivibrador".....multivibrateur may be in your language...or "biestavel"
These are nice things...lamps goes flicking very low frequency while condenser goes charging..lovely effect..we can arrange Leds together the relays...so we gonna have a lot of ligths ....this is nice...hehehehh....i like that....maybe ridiculous to others..but i like signals..lamps flashing..these things.
This needs adjustment...to our own personnal tast.that frequency...also the ligth decay time..maybe some minor modifications will be done....i will do that those next two days.... then i will offer, not my design, but my work, follow up,.....my help.
I am changing the silk screen, to help builders (if someone turns interested)... to use BC546, as this transistor has inverted leads when compared to 2N5551.
By the way, dear Gaetan (mon bon ami).... this picture you're using is nice..you are handsome..good looking guy.... seems someone we can trust..someone that has enormous heart...someone that has friends with the same value of Gold!
regards,
Carlos
File Type: jpg Transistor position reference changed to BC546.jpg (761.3 KB, 419 views)
Old 1st April 2010, 03:10 PM   #8
regards,
Carlos
Hello Carlos
Yesss, multivibrator in english, I did not remember it, but in some french book it also named bascule wen it's in a protection circuits.
Keep us in touch about it, I'm sure that many guys will use it.
Thank
Bye
Gaetan
Old 1st April 2010, 04:13 PM   #9
Default Here you have a picture..BC546 installed inverted related the positions indicated by
original silk screen.
Ice Cream is PavÍ flavour....only Latine root people can pronunciate this ending "E" letter closed.
regards,
Carlos
Old 1st April 2010, 07:50 PM   #10
Default Here you have folks..already built..tomorrow i will test
Images attached,
regards,
Carlos
Speaker delayed insertion, speaker protector, off set sensorHide this!Advertise here!
First speaker set wb8723 Multi-Way 1 16th June 2008 12:28 AM
Speaker Protector With MOSFET IrishboyM4 Solid State 2 23rd April 2007 11:49 PM
Speaker protector gaminn Parts 0 9th April 2006 05:43 PM
5 speaker set any good? Beano_The_Bimbo Multi-Way 1 17th October 2004 10:06 PM
Aleph 2 speaker protector? tomchaoda Pass Labs 9 8th January 2004 09:53 PM
Copyright ©1999-2017 diyAudio
