Speaker delayed insertion, speaker protector, off set sensor
Old 9th July 2010, 06:13 PM   #31
Mitchel is offline Mitchel  Brazil
Mitchel's Avatar
What's the web address for paijs website?
Old 9th July 2010, 06:18 PM   #32
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
audiocostruzioni.com
Old 9th July 2010, 07:54 PM   #33
Mitchel's Avatar
Thank you Andrew!
Old 11th January 2011, 12:18 PM   #34
Mamak is offline Mamak  Malaysia
Originally Posted by destroyer X View Post
seems fine..but maybe some resistance adjustment may be needed, better transistor selection, or to test ours.... timing adjustment and so on.
Seems fine...but who knows?... sometimes we find mistakes...human mistakes or layout mistakes..parts inverted and so on.
I will assemble and will be happy to let you all know.
Soon.
regards,
Carlos
do you test this protection?its work or not?
Old 17th June 2011, 04:07 AM   #35
1965GTO is offline 1965GTO  United States
If you look at the circuit as it is printed in the " Tab Electronics Guide To Understanding Electricity and Electronics", the Zener Diode is not schematically in the right direction. Look at the circuit as it is in "High Power Audio Amplifier Construction Manual" or "The Audiophiles Project Sourcebook". There the Zener Diode is in the right direction. You also need to do the math on the Rs and Iz depending on your voltage source if you are taking directly from the main power supply. All this to say that you need to flip your Zener the right direction and the protection circuit will work fine.
Old 2nd June 2014, 07:01 PM   #36
SYAHRUL is offline SYAHRUL  Indonesia
SYAHRUL's Avatar
speaker delay
Speaker delayed insertion, speaker protector, off set sensorHide this!Advertise here!
First speaker set wb8723 Multi-Way 1 16th June 2008 12:28 AM
Speaker Protector With MOSFET IrishboyM4 Solid State 2 23rd April 2007 11:49 PM
Speaker protector gaminn Parts 0 9th April 2006 05:43 PM
5 speaker set any good? Beano_The_Bimbo Multi-Way 1 17th October 2004 10:06 PM
Aleph 2 speaker protector? tomchaoda Pass Labs 9 8th January 2004 09:53 PM
