Speaker delayed insertion, speaker protector, off set sensor - Page 2 - diyAudio
Old 19th April 2010, 12:10 PM   #11
destroyer X's Avatar
Default Was not tested yet...i have not the power zener
And i have decided not to modify. in special now a days that Randy passed away..will keep as original.
It was published in Croatian forum too.
Page 278 from Randy Slone book.
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 19th April 2010, 03:38 PM   #12
Connect both relay NF terminals to speaker return/ground using 100r on each.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th April 2010, 03:51 PM   #13
event horizon's Avatar
Is it me, or is ZD1 shown the wrong way round in the circuit diagram?
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Old 19th April 2010, 04:05 PM   #14
Default Slone again
Yes, you're right. Post2 has Zd1 upside down.
regards Andrew T.
Old 19th April 2010, 05:10 PM   #15
Mooly's Avatar
Default What's this ?
I know piccys can be deceiving but is this a short ?
Old 19th April 2010, 07:42 PM   #16
Default Ahahahaha.... i know that...i was waiting someone to point that
Was you Mooly.
I know... a beautifull short i found..as i told you, not tested..only assembled and cleaned, not check and have not receive power on it.
regards,
Carlos
Old 19th April 2010, 07:43 PM   #17
Default Read the thread boys...the whole thread.... 3 times was said not checked.
I think my english is very poor....this happens a lot.
No checked, means, parts were inserted, and it is possible wrong way, wrong values, inverted transistors, NPN in the place of PNP..shorts, parts missed, lines interrupted and so on..this needs triple check before power on.
It is kind from folks to check for me..but even you doing that, for safety reasons, i will check it three times before connect supply.
You are good to observe mistakes..this means you may be good to assemble, and to check your own board.... what do you think to make one to you...i will be happy with that.
regards,
Carlos
Old 20th April 2010, 10:55 AM   #18
Hi Dx,
Your English is usually good enough.
Your posts are so long I tend to forget some of what you have said.
regards Andrew T.
Old 20th April 2010, 12:14 PM   #19
Default You memory is usually good enougth
my posts are usually short enougth...when we do not speak a good and very clear english, we have to explain two times and be very carefull to express ourselves to avoid misunderstoodings...even this way people do not understand several things and come to ask about things already explained.
Maybe you are rigth...too much long and people do not read because have not patience to read..... well...these ones have not patience to read also may have not patience to build..as build ask much more patience than to read.
So... this makes a kind of natural selection.
regards,
Carlos
Old 9th July 2010, 03:26 AM   #20
Hello Carlos, How did it go with the Protection Circuit, I think Ill build this also to test it and maybe use it with the DX Blame ST's I'm building, do u think its good enough ??
First speaker set wb8723 Multi-Way 1 15th June 2008 11:28 PM
Speaker Protector With MOSFET IrishboyM4 Solid State 2 23rd April 2007 10:49 PM
Speaker protector gaminn Parts 0 9th April 2006 04:43 PM
5 speaker set any good? Beano_The_Bimbo Multi-Way 1 17th October 2004 09:06 PM
Aleph 2 speaker protector? tomchaoda Pass Labs 9 8th January 2004 08:53 PM
Copyright 1999-2017 diyAudio
