Old 31st March 2010, 03:05 PM   #1
Default Centre tapped coil with in a coil - inductance?
What happens if you wind a coil around an iron core, stop, centre tap it, then wind the same amount of turns around (the first coi) again? (you end up with a coil within a coil)
I'm particularly interested in what the inductance would be for each half.
For example I know that..... 100 turns of 0.3mm wire yields about 0.8mH
so for this particular coil scenario, I end up with ....
100 turns of 0.3mm wire = 0.8mH
ground tap
if putting an AC signal through one half of the coil will it affect the other half? (yes I know each leg will require an inverted signal...but I'm wondering if the AC signal through one coil impacts the other, therefore playing havoc with the inductance aspect)
Old 31st March 2010, 05:13 PM   #2
Yes. It becomes a poor transformer. Both sides are coupled to each other by the core.
The inductance of a coil is proportional to the square of the number of turns. However, the inductance fo two independent inductances in series is the sum of both.
The square formula only works if both windings are on the same core.
Voice coil inductance effect karagiosis Subwoofers 8 5th September 2009 04:04 PM
HiVi B3s voice coil inductance - How to calculate? chylld Full Range 2 15th January 2009 07:10 PM
Measuring voice-coil self-inductance Klimon Multi-Way 4 19th November 2006 12:23 PM
Can I use a POT to vary the inductance of coil.......... Gavinator68 Multi-Way 7 20th May 2005 03:05 PM
voice coil inductance VS transient response kan3 Multi-Way 12 9th February 2004 08:18 PM
Page generated in 0.08022 seconds (64.94% PHP - 35.06% MySQL) with 10 queries
