#921 |
Ty mile now ill try to connect Step drive to my B 500
pls check if anything wrong with my work. |
#922 |
so the -ref is i.c.pin1,2,3,
and +ref is ic,6,7,8, the schematic must be? |
#923 |
TL072 classH Step Driver Schematic + PCB
http://apexaudio.rs/ |
#924 |
apex,
if the above is now correct,why pin 5,3 to bf422/423 base it must be pin 1,7 to bf's base |
#925 | |
#926 |
#927 |
#928 |
B500 + TL072 Step Driver for classH.
#929 |
A and B use for bridge mode, MJLs can be used instead 2SA/SC
#930 | |
| 900W H-class PA Amp with Limiter | apexaudio | Solid State | 2548 | 15th June 2013 05:55 AM |
| 500w power amplifier | juneray | Solid State | 70 | 16th September 2011 04:05 PM |
| 500W Power Amplifier | JRdGreat | Solid State | 24 | 16th September 2009 09:48 AM |
| 500W Aleph Amplifier? | lscangus | Pass Labs | 20 | 19th November 2005 08:29 PM |
| Looking for 300-500W amplifier | audioPT | Solid State | 3 | 31st August 2002 12:39 PM |
