500W PA amplifier with Limiter
Old 27th November 2010, 07:05 AM   #911
engel dela pena is offline engel dela pena  Philippines
Originally Posted by andrewlebon View Post
hi engel dela pena
greetings mytlo 72 step driver
thanking you
andrew lebon
please show i.c. pin clearer
please clarify tlo72 pin supply.
thanks
Old 27th November 2010, 07:16 AM   #912
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
hi engel dela pena
greetings yes its tested working on real 1000 watt speakers
1 tlo 72 step driver ic gets supply from 15 volt zeners on b500 pcb
2 i use IRF2807 MOSFETS GET WARM MY HEAT SINK IS THICK SO make heat
sink thicker
3 check amp with tlo72 step regulator with 100 WATT BULB IN SERIES
thanking you
andrew lebon
Old 27th November 2010, 07:58 AM   #913
Mamak is offline Mamak  Malaysia
Default b500
Originally Posted by engel dela pena View Post
thanks guys
the amp is working well
two days of testing no overheating
very good sounding amp
what transformer u use?its hard to find -+90v.what speaker u use?
Old 27th November 2010, 08:18 AM   #914
mamak,
b500 supply is 40-0-40ac
torroid,
i bought it from a surplus shop w/o coil,
and recoil it,
only using locally made speaker,but sound is clear amp is clean,many builder already testify
Old 27th November 2010, 08:24 AM   #915
Default tlo
hi engel dela pena
sink thicker
thanking you
andrew lebon
andrewlebon
one last thing mate.
w/c of this two is your pin 1?
Old 27th November 2010, 08:33 AM   #916
mamak,
torroid,
and recoil it,
i want to try build this amp and want drive pioneer car subwoofer.this amp enough to drive about 400watt amps?and my problem is build car smps.u have any circuit high power smps?
Old 27th November 2010, 08:41 AM   #917
mamak,
try this site
diysmps
Old 27th November 2010, 08:49 AM   #918
hi engel dela pena
greetings well -15 VOLTS NEGATIVE GOES TO PIN NO
1 PIN NO 8 GETS 15 VOLTS POSITIVE once u use step driver u really feel the power
thanking you
andrew lebon
Old 27th November 2010, 09:08 AM   #919
hi engel dela pena
thanking you
andrew lebon
thank you mate,
kindly attach here your answer to my previous post 915
Old 27th November 2010, 09:34 AM   #920
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Default TL072 Step
TL072 classH Step Driver: Pcb and Component Layout.
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3642 Yesterday 02:58 PM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
