500W PA amplifier with Limiter
Old 25th November 2010, 10:45 PM   #881
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay 500W PA amplifier with Limiter
Default Many thanx
Originally Posted by apexaudio View Post
80vac 40vac 0 40vac 80vac is correct,
ok ty mile ill post when im done with my new B500 with your step drive TL072
rewinding the trapo now and one more thing can this trapo 55v 35v 0 35v 55v can i use this for testing purposes?
Old 25th November 2010, 11:03 PM   #882
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
You can use it for testing class H amps (B500+TL072step, H900...).
Old 25th November 2010, 11:07 PM   #883
irvynejay's Avatar
You can use it for testing or for B250.
I mean with trapo 55vac 35vac 0 35vac 55vac can i use this on b500 with tl072 step drive for test?
Old 26th November 2010, 09:49 AM   #884
mathez is offline mathez  Indonesia
Originally Posted by engel dela pena View Post
mathez,
22r get burned when you forgot jumper wire
there is no forgot jumper wire
Can you post pictures? Do you connect input GND to PSU GND?
input GND to PSU GND is ok,.
i will post pcture soon as possible
Old 26th November 2010, 12:11 PM   #885
irvynejay's Avatar
Default upgrading B500 with Tl072 step drive
Almost done updating B500 to H class i hope it works for me
pictures attach
Old 26th November 2010, 12:54 PM   #886
irvynejay's Avatar
Default wich is correct
to mile pls help
lol my bad which of this is correct1 or 2,i just want to make sure before i connect the step drive to my b500
File Type: jpg APEX%20Hclass%20Power%20DriverMON[1].jpg (234.3 KB, 436 views)
Old 26th November 2010, 02:36 PM   #887
aman khalsa is offline aman khalsa  India
aman khalsa's Avatar
Default hi
Heating 4K7/2W is OK, what rail voltage you use?
i use 85-0-85v dc...
Old 26th November 2010, 04:58 PM   #888
apexaudio's Avatar
to mile pls help
Correct component layout is on picture 1.
Old 26th November 2010, 05:04 PM   #889
sekhar is offline sekhar  India
hey aman i saw ur build it is just great . Did u use the drive transistor as same as the output transistors...???????????/
regards
sekhar
Old 26th November 2010, 05:10 PM   #890
hi miles i was looking for some to 220 mosfets with complete plastic package so that i can use them in the step driver. using that plastic insulation for my earlier amp had lot of failure they simple use to melt. can u direct me towards some completely plastic package mosfets so that i dont have to use that plastic thing............. and one more thing can i use irfp260 or irfp250 instead of irf 540
regards
sekhar
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3649 13th June 2018 12:08 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
