500W PA amplifier with Limiter - Page 81 - diyAudio
Old 9th November 2010, 04:06 AM   #801
irvynejay's Avatar
Send a message via Yahoo to irvynejay Send a message via Skype™ to irvynejay
yes but still i cant find kse too ..anymore substitute for this i realy want to test this project
Old 9th November 2010, 04:27 AM   #802
Originally Posted by apexaudio View Post
This is maximum voltage, I suggest to use transformer 4x35-40v ac.
apex,
thanks
i will add maybe 20turns in my primary in order to subtract about 10v.
Old 9th November 2010, 12:06 PM   #803
apex,
if I add turn to primary,18-0-18 also drop voltage,
can I add more output?how many pair? for 96-48-0-48-96 ac
Old 9th November 2010, 12:14 PM   #804
apex,
by the way tlo step is working,
temporary I use step down transformer,(to step down 96-48-0-48-96 ac primary)
and the result is better,better bass more power (and still clean sound)and most important it is not dissipating heat as before(class ab b500) w/o step driver,i'm amased with this class(h),
Old 9th November 2010, 12:33 PM   #805
sekhar is offline sekhar  India
u can use 2sa1837 & 2sc4793 instead of mje340 and mje350
regards
sekhar
Old 9th November 2010, 03:15 PM   #806
noobie is offline noobie  Philippines
noobie's Avatar
apex,
two 4700uf/50v caps in series=4700/100v?
thanks
regards
Old 9th November 2010, 03:26 PM   #807
A square's Avatar
Send a message via Yahoo to A square
two 4700uf/50v X 2 in series is 2300uf/100v
thanx..
jon
Old 9th November 2010, 04:03 PM   #808
irvynejay's Avatar
Default Mje
regards
sekhar
Ty B500 is working now,ill post some picture when already in place,but i notice lower volume seems to be distorted or something..
My trafo 55 0 55 25amp ,32 0 32 25amp
Old 9th November 2010, 05:19 PM   #809
eesbiboi's Avatar
Default step drive component replacements
Originally Posted by engel dela pena View Post
apex,
engel sir...
can you please tell me which components of step drive available here in our country???...
which components are hard to find???...
and what are the components that needs replacements???...
for i am thinking of building sir apex' h class using tl072 step drive...
thanks
regards
ees...
Old 9th November 2010, 08:24 PM   #810
Dear ,
I need to get 250 watt RMS @8 Ohm from P500 , what is suitable voltage ( +/- )must I used ?
Sinan Edmond
900W H-class PA Amp with Limiter apexaudio Solid State 3521 29th January 2017 05:17 PM
500w power amplifier juneray Solid State 70 16th September 2011 05:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 10:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 09:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 01:39 PM
Copyright 1999-2017 diyAudio
