500W PA amplifier with Limiter
Old 16th April 2010, 09:12 PM   #61
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Default DC Protect
I not recomanded use amplifier without protect. This DC protect with triac is minimum for safe operation. Better is use same protect like H900 with thermal, DC and overload cut-out.
Old 16th April 2010, 10:59 PM   #62
engel dela pena is offline engel dela pena  Philippines
Originally Posted by apexaudio View Post
Is this PCB biger than original?
yes i scale it bigger than the original size
i love the original size very compact
but i'm much comfortable building it bigger as of now
for safety,no shorted or open traces
Old 17th April 2010, 12:35 AM   #63
apexaudio's Avatar
I prepared all of my old PCBs for diy:
1 single side pcb
2 available parts, no smt parts
3 line no tiny that 1mm
And still be problems
Old 17th April 2010, 01:45 AM   #64
1 single side pcb
no problem
but the thing is
you been doing this stuff for almost 30 yrs..
that means i was only 4 yrs old
you already doing this stuff
ha ha ha
by the way how old are you now miles
Old 17th April 2010, 01:58 AM   #65
i'm trying to find easy way of etching pcb
but as of now i'm still using the hard way,no software no computerized i just print the design and........then its all in my hands,
i hope i can do like the others doing it,even the tinniest lines i wish i can do that
but by the way i trully give my deepest gratitude to you
apex,
thank you very much
for sharing all this stuff
Old 17th April 2010, 02:15 AM   #66
apex,
this are the available triac & diac here
triac
Q6015L5
diac
GT-35(HT-35)
Old 17th April 2010, 11:38 AM   #67
apexaudio's Avatar
apex,
triac
Q6015L5
diac
GT-35(HT-35)
Any diac and any triac over 12A will work.
Old 17th April 2010, 11:42 AM   #68
The triac connects the rails to ground after the rail fuses.
regards Andrew T.
Old 17th April 2010, 01:34 PM   #69
apexaudio's Avatar
Triac connect output amplifier to ground if there is +/-35V DC offset, rail fuses blow and protect speakers of DC. If amplifier have not rail fuses then must put fuse on amplifier output before triac, and if there is main fuse for transformer it blow anyway. Peavey models 850, 1.3k and 2000 use DC protect with triac and have only main fuse, but there bridge recifer blow with fuse most the time.
Old 17th April 2010, 02:42 PM   #70
apexaudio's Avatar
no problem
but the thing is
ha ha ha
I think that I builded better stuff when I was younger
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3622 13th February 2018 09:56 AM
500w power amplifier juneray Solid State 70 16th September 2011 05:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 10:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 09:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 01:39 PM
