500W PA amplifier with Limiter - Page 55 - diyAudio
Old 7th August 2010, 12:40 PM   #541
then
the HV+,MV+
HV-,MV-
and ground to psu
Old 7th August 2010, 01:52 PM   #542
apexaudio's Avatar
Originally Posted by coolet View Post
@ apex tnx got it )
tnx Angel.. I'll make a new layout
so what is the +/-MV voltage? for B500
Post #537: +/-45V, do you reed it? I suggest to use for +/-MV half of +/-HV, and you can use same all caps in series for PSU.
Old 7th August 2010, 01:55 PM   #543
apexaudio's Avatar
Originally Posted by engel dela pena View Post
sorry for my lines
hope this make sense
apex pls. correct me if i'm wrong
You are wrong +/-MV connect to +/-MV not to +/-OVD. That is simple and clear I hope.
Old 7th August 2010, 06:27 PM   #544
coolet's Avatar
ok I hope this will be fine now.
the PSU is here...
Old 7th August 2010, 06:29 PM   #545
apexaudio's Avatar
Add step driver with TL072 to B500, you can use PSU from H900, and you get class H amp with same power as H900.
Old 7th August 2010, 06:34 PM   #546
apexaudio's Avatar
the PSU is here...
Yes, you have some wrong notification ( 33pF ), and why you don't try to design PCB with both circuits on it? Something like DJ.DUMY in thread:
900W H-class PA Amp with Limiter
post #435
Old 7th August 2010, 06:52 PM   #547
coolet's Avatar
thanks Apex it should be 100N. I will try to incorporate the step driver to B500 PCB.
so i will use 4x40 volts ac ... how about the tx capacity? do I reduce it?
BTW: thanks for the explanation about your Protect circuit. I check it tomorrow.
Old 7th August 2010, 06:52 PM   #548
apexaudio's Avatar
Step driver with TL072 instead with IR2117, and many diyers will be hapy and greatfull :-)
Old 7th August 2010, 06:56 PM   #549
apexaudio's Avatar
I use 1800VA transformer for stereo H900, put in 2U case with two fans. Add VI limiter, then it can be use with any protection, as I can see many diyers do not like to use protection, but B500 and H900 must be use with my original protection for PA. Fuses is not enough, but with add VI limiter will work.
Old 7th August 2010, 07:03 PM   #550
coolet's Avatar
Wow! I will have a B500 Class H... thats nice. I will do the same layout as yours since it is easy to fix in heatsink.
900W H-class PA Amp with Limiter apexaudio Solid State 3531 2nd April 2017 01:54 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Copyright 1999-2017 diyAudio
