Old 4th August 2010, 05:31 PM   #531
1.7A when on no load equates to 374W for zero secondary output.
That 374W must escape as heat.
I do not believe that the 1.7A figure has been measured correctly.
It cannot be right. The transformer would be smoking, or worse, if it was dissipating 1.7Aac @ 220Vac
Old 4th August 2010, 05:46 PM   #532
hamub is offline hamub  Zimbabwe
the figure is correct Andrew. This tx is as cold as the antarctic. I took it from a microwave oven rewound it to give 32-0-32 at the secöndary. I did not wind the primary.
Old 4th August 2010, 06:31 PM   #533
don't forget the P.F. (power factor). an unloaded transformer acts as an iron cored inductor, so most of the 374VA are VARs not watts. And it is the few watts that will contribute to the heating.
Old 4th August 2010, 07:18 PM   #534
apexaudio's Avatar
Andrew is right, if tx is cold after 10min. current measure is incorrect, and you can use it,
Old 4th August 2010, 09:29 PM   #535
alright thanks guys. I will check my measurements again and try to give the tx more time to see if he doesnt heat up. Maybe my analogue meter is lying. But thanks guys esp Mr Miles for an excitin thread.
Old 6th August 2010, 08:49 PM   #536
coolet's Avatar
Hi Apex,
Is this correct? You got PM
Old 6th August 2010, 09:16 PM   #537
apexaudio's Avatar
You need +/-45V on +MV/-MV. Colectors of MJE15032/MJE15033 must be connect to colectors 2SA1943/2SC5200, see post #402 in thread:
900W H-class PA Amp with Limiter
Old 7th August 2010, 01:30 AM   #538
Originally Posted by coolet View Post
Hi Apex,
hope this helps
Old 7th August 2010, 11:35 AM   #539
coolet's Avatar
@ apex tnx got it )
tnx Angel.. I'll make a new layout
so what is the +/-MV voltage? for B500
Old 7th August 2010, 12:33 PM   #540
@ apex tnx got it )
sorry for my lines
hope this make sense
apex pls. correct me if i'm wrong
900W H-class PA Amp with Limiter apexaudio Solid State 2540 17th May 2013 06:37 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Copyright ©1999-2013 diyAudio
