500W PA amplifier with Limiter - Page 41 - diyAudio
Old 9th July 2010, 04:29 PM   #401
sekhar is offline sekhar  India
Question can we see the pic of the transformer
Originally Posted by eesbiboi View Post
apex
sir,
i bought all the b500 components...i noticed that some components in the schematic differ from the pcb placement guide...
i need to know which one to follow...should i follow the schema or the pcb???...im using two psu for testing 1 is 50 0 50vac @20amps 2nd is 55 0 55vac @25amps...
tnx...
regards...
why do need such amp rating for ur transformer........ can we have a look at the pictures of ur transformer
regards
sekhar
Old 10th July 2010, 01:54 AM   #402
eesbiboi's Avatar
[QUOTE=sekhar;2239175]why do need such amp rating for ur transformer........ can we have a look at the pictures of ur transformer
regards
sekhar[/QUOT
i once built an amp with this psu rating with EI core...i thought of using it again...
Old 12th July 2010, 05:00 AM   #403
eesbiboi's Avatar
Default b500
my b500...
ready for testing...
only thing left to do is attach heatsinks...
Old 12th July 2010, 09:36 AM   #404
andrewlebon's Avatar
hi apexaudio
greetings can this dc protector be used with other amplifiers?
mainly the short circuit protection
thanking you
andrew lebon
Old 12th July 2010, 10:51 AM   #405
apexaudio's Avatar
Originally Posted by andrewlebon View Post
hi apexaudio
thanking you
andrew lebon
Yes, but you must have overcurrent detector on amp pcb, like B500.
Old 12th July 2010, 01:35 PM   #406
mihailo is offline mihailo  Serbia
Hi, Apex.
I have finished one shannel of B500.
Here are the pictures.
Old 12th July 2010, 01:36 PM   #407
More pictures...
Old 12th July 2010, 01:39 PM   #408
Apex120 and B500 with heatsink and my heating fan solution.
Old 12th July 2010, 01:59 PM   #409
eesbiboi's Avatar
Default dc on output
apex...
sir... i powered on my b500 circuit...
i had dc on output about 7v...
i put 2 330ohms 10watts resistor on xformer primary...
power trannies seemed to warm up...but dc occur on output...hum on spkr...no audio on output...
what seem to be the problem???...
pls help...
tnx...
regards...
Old 12th July 2010, 02:35 PM   #410
apexaudio's Avatar
apex...
pls help...
tnx...
regards...
Do not connect speakers if you have DC on output. If you not forget to connect wire jumper (red line) on botom side of pcb or GND on input with separate wire from PSU, try to measurment voltage on point as I suggest,
900W H-class PA Amp with Limiter apexaudio Solid State 3538 Today 06:36 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Copyright 1999-2017 diyAudio
