Old 1st July 2010, 11:57 AM   #381
apexaudio's Avatar
Nice try, but for this power you need something like this,
Old 1st July 2010, 12:02 PM   #382
mihailo is offline mihailo  Serbia
Found those pictures and schematics on net so I was curious does that work?
Old 1st July 2010, 12:11 PM   #383
apexaudio's Avatar
Amplifier must be in use some time (years), and than you know is it good. Regards
Old 1st July 2010, 07:58 PM   #384
Schematics.
I resized this picture because it's to big,if you want better resolution I will send you by mail.
regards
Sir can you post pcb layout of this schematics?
Old 1st July 2010, 10:12 PM   #385
Here is link of site where I have find schematics:
Google Image Result for http://www.postimage.org/PqHZCES.jpg
Old 2nd July 2010, 12:48 AM   #386
apex,
your psu
behringer torroid x-former
does this have model as you order for your 100
500 & 900 module
or is it costumized?
Old 2nd July 2010, 01:43 AM   #387
electra_ina's Avatar
Originally Posted by apexaudio View Post
Dot is katode of LED inside NSL32, resistor is on oposite side,
Thanks Apex...I see it...so I think "dot/catode" on body NSL 32 must be same with "dot" code on PCB B500/H900. Catode NSL-32 connected with R 6K8/2W and negatif dioda zener 15V. Its OK?
Pozdrav.
Old 8th July 2010, 11:13 AM   #388
Hi Apex. I have 2 questions for you:
1.What voltage do you recommend me if there are two 2SC5200 and two 2SA1943 on pcb?
2.What power will I get with +/-56V?
Old 8th July 2010, 01:29 PM   #389
apexaudio's Avatar
1,2 - two pairs 2SA/2SC with +/-56V you will get about 120W/8R (resonable THD)
Old 8th July 2010, 01:56 PM   #390
the 1943/5200 have a very poor SOAR at higher voltages.
Using +-56Vdc should give good 8ohm performance, but these devices can only manage 40 to 45degree phase angle when kept cool.
However, using +-50Vdc, an 8ohm load of 60degree phase angle can be driven to full power of ~110W. You still have to keep them cool to stay within the de-rated 100ms SOAR
900W H-class PA Amp with Limiter apexaudio Solid State 2542 22nd May 2013 06:51 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Copyright ©1999-2013 diyAudio
