500W PA amplifier with Limiter
Old 19th June 2017, 12:55 AM   #3281
saminnografix is offline saminnografix  Philippines
hi diyers'
may i ask any idea on my b500 it works well but.
the turn on ploop strikes +/-30VDC
so i have used the h900 protect stereo with tip31 thermal diodes.
there is still about +/-4.5VDC which i think not good for the speakers
Old 20th June 2017, 09:44 AM   #3282
Zinyx is offline Zinyx  Poland
Zinyx's Avatar
Originally Posted by Luuker View Post
Hi. What is the value of resistor instead of NSL32? MJE340 / 350 is the need for a cooler?
NSL32 can be replaced with 47k resistor and LED for 'clip' indicate, if you don't want use limiter,
MJE340/MJE350 need some small heatsink.
Old 20th June 2017, 10:22 AM   #3283
pallab is offline pallab  India
pallab's Avatar
One channel done for test .Audio quality superb .I have used MJL3281/MJL1302 (2pair) for test.But I will use 4 pair to get 500w at 4 ohms.
Old 29th June 2017, 01:58 PM   #3284
herimanana is offline herimanana  Madagascar
hi folks!
I'd like a advice from you all.
I want a good quality HI-FI performance amplifier and will have a power like this B500 !! I like the power of this B500 but need more HI-FI performance !!
Any circuit please !!!
A new design of b500 may be.
thank you all !!
Old 6th July 2017, 07:41 PM   #3285
pallab's Avatar
Originally Posted by wiljj78 View Post
Mr. Mile,
I'm planning to upgrade my B500 to TEF, is this correct?
I want to change predriver to mje15032/33 pair driver TTC5200/1943 pair and 5 pair mjl3281/1302 as outputs...can anyone tell me mje340/350 are equipment to mje15032/33 pair ? because I saw for tef version there all mje15032/33 instead of mje340/350.
Old 7th July 2017, 04:42 AM   #3286
Dacz is offline Dacz  Philippines
Dacz's Avatar
read darasheet
mje340/350 Ic 500mA
mje15032/33 Ic 8A
Old 8th July 2017, 06:41 PM   #3287
pallab's Avatar
I have a question.can i add one extra pair i.e total 5 pair mjl3281/1302for standard version of apex b500 without changing any component?And what will be optimal bias current for mjl3281/1302 pair at 75v dc ?
Old 10th July 2017, 12:02 PM   #3288
pallab's Avatar
https://m.youtube.com/watch?feature=share&v=myLK3RT_SL0
B500 with 2 pair output.
Old 13th July 2017, 08:56 AM   #3289
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
B500+SMPS
Old 13th July 2017, 07:01 PM   #3290
stewin is offline stewin  Kenya
Originally Posted by apexaudio View Post
B500+SMPS
nice work sir apex
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3622 13th February 2018 09:56 AM
500w power amplifier juneray Solid State 70 16th September 2011 05:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 10:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 09:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 01:39 PM
