500W PA amplifier with Limiter - Page 300 - diyAudio
Old 20th July 2014, 09:08 AM   #2991
AndrewT is online now AndrewT  Scotland
a 65Vac transformer will five you about 90Vdc to 95Vdc
a 65-0-65Vac transformer will give about +-90Vdc to +-95Vdc (190Vdc total across the supply rails).
ClassAB will blow up your 1943/5200 transistors.
Try ClassG, or ClassH, that may allow your transistors to survive.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 20th July 2014, 04:32 PM   #2992
sandman15th's Avatar
hi guy can i asked, i want to build apex psu 7 for my b500, can i replace bc517 and bc550 t0 2n5551?? thanks Click the image to open in full size.
Old 20th July 2014, 10:38 PM   #2993
TonyTecson's Avatar
Originally Posted by eper puliran View Post
sir ajt i'm using the original pairs of output 4 2sc and 4 2sa.. but i didnt try yet to supply the 85 volts dc coz i want to ask first before i try the transfoermer
Originally Posted by apexaudio View Post
For B500 2x60vAC max, but I suggest 2x55vAC for safety operate.
best to follow designer's comments,
raising the rails while giving you more power,
does not necessarily give you more spl.
using lower rails makes your output trannies
live a little longer than with high rails...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 21st July 2014, 06:05 AM   #2994
SYAHRUL is offline SYAHRUL  Indonesia
SYAHRUL's Avatar
Thnks apex...B500 all succes.
Old 21st July 2014, 06:11 AM   #2995
SYAHRUL's Avatar
B500
Old 24th July 2014, 07:02 AM   #2996
jaagut is offline jaagut  Philippines
Originally Posted by SYAHRUL View Post
B500
very very nice amp, for sure!
Old 24th July 2014, 03:35 PM   #2997
mrsavage's Avatar
Default Need Gerbers files for each PCB's
PDF versions of the PCB's are fine for making the PCB's yourselves at home,
but I would like to send the PCB's to a vendor. I have made PCB's myself but
I do not like the mess and nasty chemicals.
Unless someone knows how to change PDF PCB images into Gerbers or
something that software, like Eagle, etc., can understand, then I need
Gerbers files for each PCB. Another option is Group Buys for each PCB's.
Let me know what possible. Take care.
Old 28th July 2014, 03:29 AM   #2998
can i load this amplifier with 3 speakers sir 8 ohms each speaker..?? my supply is 54 0 54 ac 20 ampers
Old 28th July 2014, 08:36 AM   #2999
The output from a 54-0-54Vac transformer will be somewhere around 600W to 700W into 2.7ohms.
Will the output devices and drivers survive your operations?
regards Andrew T.
Old 28th July 2014, 10:15 AM   #3000
i have 3 speakers sir at 1000 watts each,, can this amplifier handle this..?? the amplifier wont be damage..//??
900W H-class PA Amp with Limiter apexaudio Solid State 3537 28th May 2017 04:58 PM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Copyright 1999-2017 diyAudio
