Old 2nd April 2010, 10:46 AM   #21
sekhar is offline sekhar  India
wat r the dimension of the pcb and is it a mirror img of the pcb?????????????
Old 2nd April 2010, 10:50 AM   #22
simple test: print it on normal paper, take an opamp an test if it aligns if not: try different sizes of prints
Old 2nd April 2010, 11:01 AM   #23
apexaudio's Avatar
Go to post #8. On PCB layout always is cooper side.
Old 2nd April 2010, 11:09 AM   #24
ok got the pcb size thanks ........ neways with wat can i replace MJ15032 it is nt available at my place
regards
sekhar
Old 2nd April 2010, 11:15 AM   #25
the pin layout of 2sc4793 & 2sa1837 r same with mje15033 & mje15032 but the collector current is a lot less for the 2sc & 2sa series wat would u recommend..............
regards
sekhar
Old 2nd April 2010, 11:48 AM   #26
apexaudio's Avatar
regards
sekhar
2sc4793/2sa1837 can be use for B500.
Old 2nd April 2010, 03:01 PM   #27
electra_ina's Avatar
Aha....one againt.. this amplifier made in Apex....I interested to build it...Thanks alot Apex audio.., you sharing this project....
Electra_ina
Old 4th April 2010, 11:39 AM   #28
apexaudio's Avatar
Electra_ina
I hope U project will be successful.
Old 8th April 2010, 12:34 PM   #29
apex,
h900 is not for me
thank you for this b500
ir2117 is not yet available in my place
unless a group buy of this ir2117 ,i have no chance of having it
since b500 and h900 parts are almost same,i already buy most of h900 parts available here,i'm glad you share this b500
can you please post b500 psu pcb and schematic
and does protect and soft start of h900 can be used in b500?
thanks
Old 8th April 2010, 01:45 PM   #30
apexaudio's Avatar
Default Apex b500 psu pcb
Protect use from H900.
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
alex mm
900W H-class PA Amp with Limiter apexaudio Solid State 2079 22nd May 2012 02:25 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Page generated in 0.11156 seconds (70.17% PHP - 29.83% MySQL) with 11 queries
