500W PA amplifier with Limiter
Old 22nd September 2013, 06:46 PM   #2651
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by nazirdigi View Post
b500 tef tested with p.audio ,challenger c18el 1200w one sub and one top per channel,(300w per speaker in top)
powerful sound,
for diy members pls try to buy 15 inch speakers or 18 inch speaker, without good speakers u cant hear the powerfull sound.
useless of making powerfull amps.
Nice work, I suggest some of my speaker box design for more powerfull sound.
Old 23rd September 2013, 06:51 AM   #2652
wattaniya is offline wattaniya
ok apex sir i will try to make ur boxes.
Old 23rd September 2013, 08:49 AM   #2653
apexaudio's Avatar
Speaker boxes is in this thread http://www.diyaudio.com/forums/pa-sy...ne-aray-3.html
Old 24th September 2013, 04:19 AM   #2654
sandman15th is offline sandman15th  Philippines
sandman15th's Avatar
hello,sir can i used 2sc3281 instead of 2sc5200?? morning to all
Old 24th September 2013, 04:44 AM   #2655
good morning to all, can i used 2sc3281and 2sc1302??? instead of 2sa1943 and 2sc5200?? thanks......waiting for your reply guys....i want to confirm first before i put this in my b500.. =) sorry double post =(
Old 24th September 2013, 07:43 AM   #2656
Ian Finch is offline Ian Finch  Australia
Toshiba 2SC3281/A1302 have been obsolete more than 13 years. Virtually all these parts still available have been fakes for many years. Perhaps you have no clue what you really have and so it would not make sense to compare them with anything unless you really can test them at high power. At 500w, you are playing with fire using bogus components.
Wingshing and Mospec (Taiwan) make fair clones, however. You can use them though Vceo is only 200V compared to 230V. Who is the manufacturer marked on your transistors?
If the Toshiba 3281/1302 parts are genuine, they will be worth more to you as collector items to sell, than any 500W amplifier!
Ian
Old 24th September 2013, 08:33 AM   #2657
=) thanks for the reply, this one is toshiba made in japan.. i have four of this..=)
Old 24th September 2013, 10:24 AM   #2658
Originally Posted by sandman15th View Post
=) .................is toshiba made in japan.. i have four of this..=)
if you bought these recently (say in the last 5years) then they are probably fakes.
regards Andrew T.
Old 24th September 2013, 10:51 AM   #2659
It would be a very stupid fake that didn't have identical markings to the originals, if it said Toshiba.
Now, what is the colour of the 2SA1302? When and where did you buy them?
In any case, won't you be needing quite a lot more and matched pairs to build a 500W amplifier?
Ian
Old 24th September 2013, 11:16 AM   #2660
Techpolice is offline Techpolice  Philippines
@andrew t
i build b500.when i test it with +-24 volts the amp works fine but when i replaced the supply with +-55 volts the + fuse blown and the trannies were damage.what could be the culprit of this problem?
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3622 13th February 2018 09:56 AM
500w power amplifier juneray Solid State 70 16th September 2011 05:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 10:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 09:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 01:39 PM
