500W PA amplifier with Limiter 500W PA amplifier with Limiter - Page 256 - diyAudio
Old 24th April 2013, 07:18 PM   #2551
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Hello guys
Yesterday I post a file but I found and error on this layout, I'm going to share this because I have learn a lot from you guys and it will be not fair not to share my ideas, I mainly like just layouts and must of the time I like to use B500 and AX-14 as reference, so for you guys that use Sprint Layout 5 here is the files call it "B500 and more", so you can use them of course as diy not for sale or profit please use this files only to create images for etching, I'm not an expert but if this files are useful for any want that like layout feel free, you can use them, please if some one with more expertise see an error please let me know some times there are errors you don't see when eyes are tired.
Juan
Old 25th April 2013, 08:21 AM   #2552
duran_1960 is offline duran_1960  Turkey
Default Thank You !
Thank you very much LIEM POO your kındest helping and most valuable contribution
Old 25th April 2013, 02:26 PM   #2553
Jonsen is offline Jonsen
Default b500
hi fnd.can you tell me how to bridge this amp.
Old 25th April 2013, 04:42 PM   #2554
khalsa is offline khalsa  India
Send a message via Yahoo to khalsa
Default bridge wiring
Hi Sadaru use this wiring
Old 28th April 2013, 06:44 PM   #2555
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
B500 with SMPS
Apex B500 & SMPS 1kW - YouTube
Old 2nd May 2013, 10:16 AM   #2556
Gassanov is offline Gassanov  Indonesia
Default b500 tef need correction
Please need you correction. This is the first time in my i live i made PCB using computer, Damm! i hate drawing
Board dimension is 37.7cm x 6.2
Any correction before I'm inserted the protector and fan control ?
regards
Old 2nd May 2013, 01:58 PM   #2557
Gassnov hi sir how long "size" is that board image? remember if you are to print that maybe it will be way to large in order to print out for etching, I'm not an expert but I recomended keep it simple as the original I also copied too, but 37.7 cm is about 14 inches is way to long for etching unless you are going to order that sending the gerbers the protection fan in my opinion should be separate I mean if you want it together maybe can be or not a good idea. about the pair maybe you will be ok with 5 pairs so you can reduce the size of the board I mean that is my opinion maybe other experience guys have a different thought, about you hate the drawing you did a pretty good job just analyze what can be done to make it work (size considerations, numbers of pairs, protection separate or not, traces sizes, "I always try to keep them at 1.50 mm" pad sizes 2.50 mm diameter, (if possible), correct component sizes, I always use DigiKey they have plenty of info for components measurements, also the board thickness your board has to be at least 2 mm thick so it will be not much flexing other words bend to much, ok sir I hope your project goes smoothly and work great good luck.
Juan
Old 5th May 2013, 11:16 AM   #2558
Riff is offline Riff  Indonesia
Riff's Avatar
regards
nice...
working with diptrace?
Old 5th May 2013, 04:49 PM   #2559
rizqi is offline rizqi  Indonesia
rizqi's Avatar
Send a message via Yahoo to rizqi 500W PA amplifier with Limiter
This is simple but Higher out...
just 35cm its have enough..
Better try it ...
Old 14th May 2013, 07:55 AM   #2560
ihsan07 is offline ihsan07  Indonesia
Hi Mile,,whether the apex B500 bridge mode can be done like this
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3547 23rd July 2017 01:57 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Copyright ©1999-2017 diyAudio
