500W PA amplifier with Limiter
Old 8th March 2013, 10:05 PM   #2501
Gassanov is offline Gassanov  Indonesia
Originally Posted by ahmadfay View Post
and this is from apex audio
How many watt you get using this method "TEF" ?
Salam kenal
Old 9th March 2013, 12:29 AM   #2502
ahmadfay is offline ahmadfay  Indonesia
ahmadfay's Avatar
Salam kenal
I assemble with 8 pairs toshiba, using 15 A transformer with voltage 2 x 55 Vct. I used to drive speakers faboulus 2 x 18 "4 ohms, the result is very satisfactory, i like it
Greetings also
Old 9th March 2013, 04:12 AM   #2503
vedmitraa is offline vedmitraa  India
vedmitraa's Avatar
55-0-55 A.C. that is around 77-0-77 Volt D.C. if I am correct not 90-0-90 as in layout, Did you have to put a delay start in it, how was the heat of outputs on load,Is there any more changes in component value in your layout.thanks in advance for getting the reply.
Failure in Experiment is key to success .Only right combination is needed.
Old 9th March 2013, 04:35 PM   #2504
wendipassundan is offline wendipassundan  Indonesia
wendipassundan's Avatar
Default correction layouts
I will make a B500 with a length of 30cm, please in this layout correction if there is a mistake,,,, sorry my bad english. Thank you so much.
Old 10th March 2013, 09:43 PM   #2505
Salam kenal
Cool. Thx 4 the info bro
Old 10th March 2013, 09:44 PM   #2506
Bikin yg pake sanken kang, 8 batang sekalian
Old 11th March 2013, 08:38 AM   #2507
vedmitraa's Avatar
MR.Wendipassundan , This one is not tripple ef as of Ahmadfay
Old 11th March 2013, 11:11 AM   #2508
Originally Posted by vedmitraa View Post
No sir MR Vedmitraa, B500 is the only standard length are changed, I happened to have a heatsink 30cm. There is nothing wrong with the layout sir??
thk
Old 11th March 2013, 11:18 AM   #2509
Default psu
thk
Old 11th March 2013, 02:16 PM   #2510
Default layout protect
please correct protector for layout......
thk.
File Type: pdf apex protector 2_ bott_wendys+dhean.pdf (26.8 KB, 560 views)
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3649 13th June 2018 12:08 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
