500W PA amplifier with Limiter
Old 24th February 2013, 10:17 AM   #2481
PetruV is offline PetruV  Romania
Any links?
Old 25th February 2013, 04:47 AM   #2482
ahmadfay is offline ahmadfay  Indonesia
ahmadfay's Avatar
Originally Posted by PetruV View Post
Yes but 2x 55v 7-10a transformer is ok for one chanel
thank you, PetruV
regard
Old 25th February 2013, 07:30 AM   #2483
Originally Posted by ahmadfay View Post
thank you, PetruV
regard
Noooooo i was asking a question not answering, it may be wrong what i said
Old 26th February 2013, 01:13 AM   #2484
ahmadfay's Avatar
but, I'll try use 15 A, 2x 55VAC, may be better than ever
Old 26th February 2013, 05:13 PM   #2485
that will be 1500w wich will be good even for two chanels
Old 26th February 2013, 07:49 PM   #2486
You get 77 volts from 55v trafo so i think it will work
Old 1st March 2013, 05:22 AM   #2487
ahmadfay's Avatar
Click the image to open in full size.its mine, b500 tef with 3 pair
Old 1st March 2013, 06:31 AM   #2488
marjuni is offline marjuni
Hi ahmadfay can you share layot & skema
regard
Old 1st March 2013, 06:53 PM   #2489
Your design is interesting,the way you have the transistors mounted
Old 1st March 2013, 11:57 PM   #2490
ahmadfay's Avatar
This test only, next i will be using 7 pairs final transistor.
regards
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3649 13th June 2018 12:08 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
