500W PA amplifier with Limiter - Page 247 - diyAudio
Old 19th February 2013, 03:47 AM   #2461
Who want like this heatsing power BUILT UP with long 40cm and height 12cm...
Just $ 16.5./piece
Position in INDONESIA...
File Type: jpg 736830_552449501434366_1221338065_o.jpg (295.3 KB, 1238 views)
Old 19th February 2013, 12:40 PM   #2462
What is the safe voltage for B500 with 3 pairs of transistors?
It will be used only for 8ohms load.
I need about 250-300W.
Old 20th February 2013, 10:53 AM   #2463
Did you mean: adakah layout versi b500 TEF
is there a version of the B500 TEF lay out
Old 21st February 2013, 12:00 PM   #2464
PetruV is offline PetruV  Romania
After all im going to build this amp,this is a little more complex but i think its ok,\
I need pcb pdf so when i print it its the correct size
Old 21st February 2013, 03:12 PM   #2465
apexaudio's Avatar
This CCS circuit add to B500 instead resistors feed zeners with 30mA with any rail voltage.
Old 21st February 2013, 03:36 PM   #2466
So the power to 5532 is more stable and it will sound better,also we will be able to get more power by increasing the voltage past the 90v mark and adding more outputs
Old 21st February 2013, 04:01 PM   #2467
apexaudio's Avatar
Power to NE5532 (+/-15V) will be stable from +/-30V to +/-90V rail voltage without any changes.
Old 21st February 2013, 04:10 PM   #2468
Aniways i need a .pdf pcb and layout
Old 21st February 2013, 08:40 PM   #2469
And what voltage and current transformer will i need for 1 chanell(im going to use one trafo per chanell)
Im going to rewind microwave transformers since theire cheap
Old 22nd February 2013, 07:08 AM   #2470
ahmadfay's Avatar
hi Apex, I have made TEF B500 and have been successful, but there are a few questions:
1. predriver transistor (MJE 350/340) and driver (5200/1943) is rather hot, is this normal?
2. how much minimum voltage for B500 TEF?
Thank you,
900W H-class PA Amp with Limiter apexaudio Solid State 3521 29th January 2017 05:17 PM
500w power amplifier juneray Solid State 70 16th September 2011 05:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 10:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 09:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 01:39 PM
Copyright 1999-2017 diyAudio
