500W PA amplifier with Limiter
Old 8th February 2013, 09:06 AM   #2431
Gassanov is offline Gassanov  Indonesia
Default Thx mile
Dear sir apex....just wanna say thx for sharing your design in to the diy comunity, 2days ago i just finish build this super clean amp and the sound is so cristal clear! I cant event heard any noise came out from the speaker. This is super! Cant wait to try H900.
Thx again mile.
Old 8th February 2013, 03:33 PM   #2432
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Thx again mile.
Can you post pictures?
Old 9th February 2013, 12:23 AM   #2433
Why not? this is how its look:
Few things need to be done:
1.Replace 680R with 1kohm Trimpot to adjust bias (i still heard crossover distortion when i use signal generator from my iPad).
2.Speaker Protector and Zobel 10uh,10ohm Resistor
3.Balanced Input
4.Subwoofer amp. i plan to use another b500 or HV230 as sub amp.
5.Add thermal protection.
thx again sir mile...this is the best amp I've ever build.
Old 9th February 2013, 01:09 AM   #2434
nugroho is offline nugroho  Indonesia
Just Use in series,
18v and 47v using two Oki 10amp transformer (ignore the CT).
Conect 18v from Oki 1 to 47 volt Oki 2 transformer and Use it As CT.
So you will get 18+47 x2
So the pin will be 18, CT and 47 from the second transformer.
Dont forget to Use HI voltage capasitor, im using rayden 10000uf/100v in series and parallel configuration.
Goodluck
Regards from bekasi
Sorry for double posting.
i'll try to understanding that, can you share the diagram connection of those 2 tranformer?
regard
Old 9th February 2013, 03:47 AM   #2435
regard
simple drawing...hope it help
Old 9th February 2013, 05:57 PM   #2436
Vostro is offline Vostro  South Africa
Vostro's Avatar
@ Gassanov, how much power are you thinking about for sub?
Have you had a look at Mr Apex's Class D amp,
Maybe good idea, and needs less heatsinking.
Old 10th February 2013, 12:09 PM   #2437
apexaudio's Avatar
3.Balanced Input
Nice amp,
Old 10th February 2013, 09:29 PM   #2438
@vostro...thx for your sugestion.
I need At least twice the power of b500, maybe 500watt @ 8ohm is enough.
To be honest i dont like class d topology, mixing audio signal with square wave, its like a dithering technique in computer DAW for converting hi bit depth to lower bit depth...its sims fake to me. I know class d Efficiency is higher than class ab and also less heat, but class H seems more Efficient to me. Do you have any other suggestion?
Thx B4.
Old 10th February 2013, 09:35 PM   #2439
apexaudio's Avatar
Gassanov, use H900 for sub amp.
Old 10th February 2013, 09:44 PM   #2440
Thx again sir mile.
Do you have sugestion for bias trimmer? which resistor i should changes? 680 or 330?
I realy need fine addjusment here to get rid of those crossover distortion. Maybe adding 1kohm trimmer series to 220ohm like you did in SR50 studio reffrence monitor is ok to B500?
Thx B4
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3649 13th June 2018 12:08 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
