500W PA amplifier with Limiter
Old 21st January 2013, 10:30 AM   #2411
powerflux is offline powerflux  Netherlands
Originally Posted by tranceanddance View Post
for PSU spec 55vac 25A they count(where I order transformer) for me 2500Wt transformer! how it can be?!!! ((
maybe 25A/secondary, so 50A in parallel?
Old 21st January 2013, 11:09 AM   #2412
tranceanddance is offline tranceanddance  Ukraine
tranceanddance's Avatar
i dont understand why they count parallel 50A?
what I should exactly say to transformer factory?
I said to them P=1000wt, +-55vac, 25A
maybe anything else I have to specify more to them?
Old 21st January 2013, 12:08 PM   #2413
you need to tell the supplier/manufacturer:
Input voltage
Output voltage
Number of secondary windings
Regulation
VA
eg.
230:40+40Vac dual secondary. 1000VA, 3 to 4% regulation.
That's all.
You don't need to know the current rating, you don't need to tell them the current rating.
You ask why?
Because you are not using the transformer to feed AC to a resistor load.
And that 1000VA will satisfactorily power a 500W to 1000W amplifier or set of amplifiers with a total maximum output of 500W to 1000W.
You are feeding the output to a capacitor input filter. The current rating goes out the window when a non resistor load is used.
regards Andrew T.
Old 21st January 2013, 01:27 PM   #2414
Thank you very much !
ps: what do you mean 3 .. 4% 'regulation' ?
Old 22nd January 2013, 10:55 AM   #2415
Input voltage
Output voltage
Regulation
VA
eg.
That's all.
You ask why?
I understood it, but anyway.. I sended my psu info allready to 3 manufacturers and all of them ask me what current have to be at secondary...if I tell them 25A, they said it will be 2*55V*25A=2750VA transformer!!!
please, help why like this....
Old 22nd January 2013, 02:30 PM   #2416
and if I dont tell to them any current, they write this spec for ready psu:
1350 VA, 50Hz 220В
1: +55В under load 12,3А
2: -55В under load 12,3А
(D*d*H) - 186*47*78 мм
9,92 kg
or
1000 VA, 220v, 50Hz
1: +55В under load 9,1А
2: -55В under load 9,1А
(D*d*H) - 184*52*74 мм
9,11 kg
but 9,1A or 12.3A dont enough for 2 chanels stereo , am I right?!
Old 22nd January 2013, 03:06 PM   #2417
.................but 9,1A or 12.3A dont enough for 2 chanels stereo , am I right?!
No, you are not right.
Remember I told you
regards Andrew T.
Old 22nd January 2013, 04:34 PM   #2418
ok! then why they write on psu spec " xxV under _xxA load_ " ? I mean..for what ?
thank you
Old 22nd January 2013, 08:18 PM   #2419
I'm sorry about stupid quiestion, they write it for R load of course...
so, Iam ordering this one
1000 VA, 220v, 50Hz
9,11 kg
hope everything is clear now to start the amp building
and big thanks to all DIY users for help
Old 27th January 2013, 08:54 AM   #2420
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
they request current ratings for all secondary windings because not all secondary windings must have the same power ratings. in case of 1000VA transformer,they donīt know if you need 700VA from one 55Vac secondary,100VA from other 55Vac secondary,190VA from one 18Vac secondary and 10VA from one remaining 18Vac secondary/or you need 950VA from both 55Vac secondaries to power amp and 50VA to power other circuites in amp other than output stages. not all the secondary windings must have the same power ratings,but they all together should have power equall to a primary winding/total transformer power.
If you are building 2 B500 chanels,i would use at least 1500VA transformer.
Chop your own wood and it will warm you twice
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3607 27th December 2017 02:02 AM
500w power amplifier juneray Solid State 70 16th September 2011 05:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 10:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 09:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 01:39 PM
