#2391 |
please, help!! is it ok transformer 628VA 73Vmax for both stereo chanel ?!
I mean if its not enough power, what can be happen? The deal is that I Have this psu and 700wt petrol electricity generator as a power suply for all that |
#2392 |
#2393 |
thank you very much ! and what about stereo minimum requirements for PSU (500wt*2) ?
VA,Vmax,A... |
#2394 | |
#2395 | |
or go to 3ef and you can bridge mode with 4r load. regards... |
#2396 |
thanks! how about amperes, how much amperes should give PSU, how to calculate it in right way ?
#2397 | |
for example, how much Vac I need from 1000Wt psu..or 700wt..or 640wt psu... for stereo mode ?! how to calculate it ?! hope to get an answer, thank you in advance !!! Last edited by tranceanddance; 19th January 2013 at 09:45 PM. |
#2398 | |
hope this will help you. regards. |
#2399 |
thanks, i know that formules, but still have little misunderstanding..i mean...for example
if I have 1000VA transformer, how can I calculate how much U and I i must have for this amp? I know only one thing - P(W)-1000wt(stereo mode), how I can calculate U(volts) and I(amperes) ?! P=UI, so i need to know more or U or I to get almost all I need to build PSU what is algorythm? Last edited by tranceanddance; 20th January 2013 at 07:09 AM. |
#2400 | |
(PxR)sqrt=vrms (500x4)sqrt=44,72 P/vrms=I 500/45=11,11 so for real 1kw stereo is 45vrms at 22,22A or PSU spec is 55vac 25A. |
| 900W H-class PA Amp with Limiter | apexaudio | Solid State | 2542 | 22nd May 2013 06:51 AM |
| 500w power amplifier | juneray | Solid State | 70 | 16th September 2011 04:05 PM |
| 500W Power Amplifier | JRdGreat | Solid State | 24 | 16th September 2009 09:48 AM |
| 500W Aleph Amplifier? | lscangus | Pass Labs | 20 | 19th November 2005 08:29 PM |
| Looking for 300-500W amplifier | audioPT | Solid State | 3 | 31st August 2002 12:39 PM |
