500W PA amplifier with Limiter
Old 12th December 2012, 01:17 PM   #2341
rizqi is offline rizqi  Indonesia
rizqi's Avatar
Send a message via Yahoo to rizqi 500W PA amplifier with Limiter
Default b500tef driver
Better try it ...
Old 12th December 2012, 05:45 PM   #2342
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
Originally Posted by rizqi View Post
nice one!
Chop your own wood and it will warm you twice
Old 12th December 2012, 10:11 PM   #2343
suryadi5417 is offline suryadi5417  Indonesia
Originally Posted by veljko View Post
B500 with 5 pairs of output tr.
would you show the bottom of the layout, pleaasseee...
Old 13th December 2012, 05:18 AM   #2344
veljko is offline veljko
Layout and pcb.
Ver. wit 6 pair of outputs require A3 format of printwork.
No changes from original, only 1 or 2 pairs of tr. more.
Old 13th December 2012, 06:56 AM   #2345
wattaniya is offline wattaniya
with 5 or 6 pair output, u need tef driver stage,
without tef driver stage maximum 4 pair outputs for safety.
Old 13th December 2012, 07:22 AM   #2346
I'm not using toshiba's, have done some testing with diferent outputs with much less beta-drop on another amps and endup werry well. Gonna make one of this 2 ver for fun anyway, not for real PA.
Old 13th December 2012, 10:35 AM   #2347
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
hi apex sir,
this is my b500 5 pair output,
bottom pcb before etching and top pcb printed.
here is the bottom layout.
Hello Nazirdigi,
How's the outcome of this project? is it successful?
what's the different compare to 4 pair?
Old 13th December 2012, 12:23 PM   #2348
Originally Posted by wiljj78 View Post
Hello Nazirdigi,
with 4 pair 5pair 6pair same power, for five or six pairs stress for drivers.
Old 13th December 2012, 02:36 PM   #2349
with 4 pair 5pair 6pair same power, ...
This statement is true if you add at the end "with the same psu voltage"
..., for five or six pairs stress for drivers.
This one might be if you specife type of outputs
Regards.
Old 14th December 2012, 02:16 PM   #2350
SERGIODS is offline SERGIODS  Peru
That gives advantages if you use six pairs.
1.-power increases.
2.-votaje to the PLS is the same.
3. - We need to increase the font ampreraje.
4.-As to amending bias amperage.
5.-If aumeto the eight or more pairs to get some advantage.
Postscript: Veljko, thank you very much for uploading all this information.
best regards, Sergio.
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3649 13th June 2018 12:08 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
