500W PA amplifier with Limiter
hello diy'ers can anyone send me a complete schematic, pcb layout and component placement guide for apexaudio b500 amp? My email is jlcastro77@yahoo.com. I am planning to build 1 channel to be used as subwoofer aplifier. If you can include the recommended PSU, speaker protector and power on delay circuit i would appreciate.
sir,...
everything you need is in the thread...
reading the pages would certainly give you everything...
it will also give you ideas on how to build the circuit base on sir mile's advices...:):):):)
regards...
this one my project.....
URL]
sir i calculated the psu requirement in the the following way
P=V X V / R
root over of 500 X 4 = V
that is = 45V approx
current requirement = V/R
assuming 45 V Secondary = 45/4 = 11.25A per channel
so the transformer rating required as per my assumption will be 45-0-45 @ 23A for stereo Operation for 500W at 4E, that equates upto = 2070VA
sir,
there is some thing that I dont understand about designing Psu For an amp ...... what wrong am i doing kindly guide me through.....cause ur and my calculation r nt matching what am i missing .........
regards
sekhar
