500W PA amplifier with Limiter
Old 12th August 2012, 08:25 PM   #2231
vedmitraa is offline vedmitraa  India
vedmitraa's Avatar
Sorry for typing mistakes. attached with are some of my workshop photos.
Old 13th August 2012, 03:27 AM   #2232
khansa10 is offline khansa10  Indonesia
thanks
Old 15th August 2012, 03:41 PM   #2233
totski is offline totski  Philippines
Originally Posted by apexaudio View Post
Short circuit protect is activ only with more than 9A current per outputs (2,8V on resistor 0,33R/5W) and you have AC signal on PRO terminal. You can't have this current with serial bulb and 10R resistors. Short circuit is stres for outputs and you can't have 100% protect, do not short circuit amp out it's risk.
sorry miles i mean the amp not the protect, amp has shorts on copper lines.Mr Miles another question when i increase volume to maximum, protect activate need to reset to work again load test in 4r and 8r without tone control what could the cause?
Old 15th August 2012, 09:46 PM   #2234
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Peak current 36A with 8R load... !? Check resistors value and post pictures...
Old 16th August 2012, 12:14 AM   #2235
you are right sir upon inserting parts to my 2nd amp i found out one resistor (r5,47k) instead i insert a wrong value of 4.7k i think this might be the cause of over current that activated the protect.
Old 16th August 2012, 01:26 AM   #2236
warning! MJE350 FFFFFFFFFFFFFFFake! two of the same thing different types, one is npn the other pnp. diyer's check first
Old 16th August 2012, 12:02 PM   #2237
I can see why you have a ! followed by a ?
36Apk through 8r0 requires a load Vdrop of 288Vpk !!!
regards Andrew T.
Old 17th August 2012, 04:00 PM   #2238
MR MILE, IS THIS VI LIMITER IN CIRCLE WITH RED? IF I'M NOT WRONG CAN THIS USE IN B500 AND H900?VALUES OF RESISTOR WITH FP WHAT DOES IT MEANS?
Old 17th August 2012, 06:16 PM   #2239
apexaudio's Avatar
Yes this is VI limiter and it can be use in B500, FP is flame proof resistor but you can use regular 22k 0,5W resistor.
Old 18th August 2012, 05:28 AM   #2240
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
" !? " usually means something like "i can't beleive..." just like your " !!! " means "do you even know what i am talking about?"
Be a man,not a resistor.
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3568 18th October 2017 01:47 PM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Copyright ©1999-2017 diyAudio
