500W PA amplifier with Limiter
Old 17th June 2012, 03:31 PM   #2101
DAMANHURI is offline DAMANHURI  Indonesia
DAMANHURI's Avatar
Originally Posted by Maxmud View Post
My pcd, Who says that?
Attachment 287779
Nice PCB
Best regards - Damanhuri
Old 18th June 2012, 02:28 PM   #2102
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default b500
Hi Apexaudio
greetings well i made your triac soft start my torridal has 13swg
in primary 11swg in secondary what must be the 50 ohms resistance wattage i am using TRIAC BTA41 40 amperes is it ok or should i replace with higher ampere triac
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 18th June 2012, 03:05 PM   #2103
Default softstart
hi
greetings is NTC softstart better no big resistances
warm regards
andrew lebon
Old 18th June 2012, 04:46 PM   #2104
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by andrewlebon View Post
Hi Apexaudio
warm regards
andrew lebon
BTA41 40 is ok, 50 ohms resistance must be 25W and you can use NTC for this soft-start also.
Old 19th June 2012, 01:24 PM   #2105
jacobsetti is offline jacobsetti  India
Mile what is the frequency response of this B500 amplifier
Old 20th June 2012, 09:03 AM   #2106
jofual is offline jofual  Indonesia
Default nice
Attachment 287779
What amplifier is this Sir..?
Old 20th June 2012, 02:04 PM   #2107
popoh is offline popoh  Indonesia
What maximum supply B500 52AC or 64AC
thankss.
Old 20th June 2012, 05:11 PM   #2108
wattaniya is offline wattaniya
thankss.
55v ac
Old 20th June 2012, 07:42 PM   #2109
Maxmud is offline Maxmud
jofual
This PCB 2x200 watt amplifier apex. I sent you the mail pcb.
Old 21st June 2012, 07:57 AM   #2110
anchewrycortpriez is offline anchewrycortpriez
i am interested in your H900 can you share the schematic and PCB layout, great thanks,,,
500W PA amplifier with LimiterHide this!Advertise here!
900W H-class PA Amp with Limiter apexaudio Solid State 3649 13th June 2018 12:08 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
