#2041 |
What is this last picture? Is it an amplifier? What kind it its?
#2042 |
What will happen when I change C5 from 470pf to 560pf in B500
#2043 |
dear apex sir,
what are the wattage of amplifier used in big cinema theater ?can i look that type of system used in that.which type of transistors are used in that.thanks |
#2044 |
#2045 |
hi Nazirdigi
greetings something wrong with tef tried it today warm regards andrew lebon
[image] [/image]"It's Better to try and fail than to never know and always wonder"
#2046 |
Hi Nazirdigi
greetings please can you post which schematic you following warm regards andrew lebon
#2047 | |
i am following these schematic. |
#2048 |
B500 TEF IN PROGRESS.
#2049 |
hi apex sir, pls help,
in b500 protection section can i connect 22k resistor to any one of the outputs of 1943 emitter. in the image it connect to last output of 1943 emitter. is it possible? can i use emitter resistor .22/5w instead .33/5w.? Last edited by nazirdigi; 31st May 2012 at 11:59 PM. |
#2050 |
hi apex sir,
can i test with two pairs of output with 50vdc in tef. |
| 900W H-class PA Amp with Limiter | apexaudio | Solid State | 2548 | 15th June 2013 05:55 AM |
| 500w power amplifier | juneray | Solid State | 70 | 16th September 2011 04:05 PM |
| 500W Power Amplifier | JRdGreat | Solid State | 24 | 16th September 2009 09:48 AM |
| 500W Aleph Amplifier? | lscangus | Pass Labs | 20 | 19th November 2005 08:29 PM |
| Looking for 300-500W amplifier | audioPT | Solid State | 3 | 31st August 2002 12:39 PM |
