500W PA amplifier with Limiter - Page 201 - diyAudio
Old 2nd May 2012, 07:56 PM   #2001
apexaudio's Avatar
Originally Posted by comasus View Post
Hi! Mile
The HF instability problem was solved i dont know how it was happen
but need to increase treble response its not even like ax-14
please help me mile
Joel
Use preamp with tone control like http://www.diyaudio.com/forums/analo...q-preamps.html
Old 8th May 2012, 11:53 AM   #2002
hi apex sir,
my b500 is working perfect without chassis, but i put hole gadgets inside the chassis and now big hum is coming through speakers, what is the reason for this?
Old 11th May 2012, 09:04 AM   #2003
apexaudio's Avatar
Originally Posted by nazirdigi View Post
hi apex sir,
Did you connect GND to chassis and in what point?
Old 11th May 2012, 11:26 AM   #2004
i connect GND to near the power transformer.
Old 14th May 2012, 05:37 AM   #2005
B500 TRIPLE DARLINTON,
neet to put 10k pot and 47r base to emmitter to drivers.
pcb size 70mm by 230mm.
Old 14th May 2012, 12:00 PM   #2006
apexaudio's Avatar
Connect GND near to the input terminals (post #54)
Old 14th May 2012, 07:46 PM   #2007
For BIAS setup R22 should be 1k2 instead 680R for triple darlington output stage, and R23 is correct 330 ohms.
Q5 (MJE340) must be on main heatsink with outputs.
Predrivers MJE340/350 can use smal heatsinks, but no need.
hi apex sir,
is this r22, r23 value correct for triple darlington.
in h900 thread u said post no 2060 image value is correct, both values are different values, pls verify this.
only I'm 100percent success with Ur amps,
Old 14th May 2012, 11:52 PM   #2008
nix is offline nix  Philippines
hi nazirdigi
do you have pcb copper side of this layout?
regards
nix
Old 15th May 2012, 06:06 AM   #2009
Originally Posted by Tony View Post
yes, you have a gain of x45, a 1volt input should drive your amp to almost clipping.
Sir,
I think pre amps can solve your problem effectively...
Old 15th May 2012, 06:08 AM   #2010
Hi! Mile
I tried compensating with 47pF caps but didn't worked still the zobel resistor is getting warm
if amplifier is used continuously that is oscillating then are there any possibilities of weakening of output transistors that leads to poor sound quality and power??
Sir,
If u r using the thinner wire in zubel then it will also occur.
900W H-class PA Amp with Limiter apexaudio Solid State 3531 2nd April 2017 01:54 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Copyright 1999-2017 diyAudio
