500W PA amplifier with Limiter - Page 200 - diyAudio
Old 13th April 2012, 05:16 AM   #1991
DAMANHURI's Avatar
Originally Posted by MATSAZILIN View Post
Good gesign. Damanhuri.
Thanks Sir Matsazilin
Best regards - Damanhuri
Old 13th April 2012, 08:06 AM   #1992
vedmitraa's Avatar
Very nice P.c.b. Damanhuri.
could you send pdf files to me vedmitraa@gmail.com
warm regards
Vedmitra Sharma
Old 13th April 2012, 12:34 PM   #1993
khalsa is offline khalsa  India
Send a message via Yahoo to khalsa
very nice pcb Damanhuri
Old 16th April 2012, 05:01 AM   #1994
DAMANHURI's Avatar
Thanks Broe Khalsa.
Old 16th April 2012, 11:34 PM   #1995
Originally Posted by apexaudio View Post
B500 based on schematics of H900, but in AB class.
Power supply +/-90Vmax.
hello, first of all I take this opportunity to greet him from Argentina, and I would inquire about the function of the component that is marked as ldr, of course, thanks and sorry for the inconvenience
Old 24th April 2012, 08:43 PM   #1996
taj1989 is offline taj1989  Hungary
Hi! I've built this amplifier with 5 pairs of transistors, without protection and limiter:
I tested it today from a +-30V regulated power supply. On the outpur I measured -30V, but the transistors aren't dead, fortunately I limited the current to 200mA on the supply. Can somebody help me what should I check on the circuit? Can this hapen because there isn't enough voltage on the opamp?
Thank you for your help!
Old 24th April 2012, 10:10 PM   #1997
apexaudio's Avatar
For test with +/-30V rail voltage replace 4k7/2W with 1k/2W, and connect input gnd to psu gnd.
Old 26th April 2012, 09:19 PM   #1998
hello people, I wanted to consult those who have assembled this amplifier function of the component that is marked with "LDR" from already thank you very much and greetings to all.
Old 27th April 2012, 09:32 AM   #1999
JOHN BALI's Avatar
Hi luisitoloco22,
that "LDR" use for limiter actually it is part of NSL32(LDR + LED), not used if you don't want to use limiter. You can use 1 resistor + 1 LED instead
Thank you, I wish you happy
peace & G B U
Old 2nd May 2012, 02:23 PM   #2000
comasus is offline comasus  India
Default @Mile
Hi! Mile
The HF instability problem was solved i dont know how it was happen
but need to increase treble response its not even like ax-14
please help me mile
Joel
900W H-class PA Amp with Limiter apexaudio Solid State 3521 29th January 2017 05:17 PM
500w power amplifier juneray Solid State 70 16th September 2011 05:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 10:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 09:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 01:39 PM
Copyright 1999-2017 diyAudio
