Old 26th January 2012, 10:31 AM   #1911
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
either will do....but you can ask him how much will each one weigh? i'll get the heavier one....
Old 26th January 2012, 11:47 AM   #1912
thanks tony for reply,
i asked the weight and reply asap.
Old 11th February 2012, 02:33 PM   #1913
comasus is offline comasus  India
@Mile
could you please tell which capacitors varies bandwidth and slew rates
and also i need to increase bandwidth of this amp especially at highs...
thank you
Old 14th February 2012, 05:42 AM   #1914
Power output B500 and H900
Old 15th February 2012, 03:49 AM   #1915
Sir apex, can you replace optoresistor with optotransistor?
Old 15th February 2012, 05:45 AM   #1916
Originally Posted by apexaudio View Post
If was no mistakes...
PCB size: 220x52,5mm
If i just put the same parts (mentioned on pcb) it will works ?
Old 15th February 2012, 05:59 AM   #1917
Sir,
Would u please explain that what are the " A, B & PRO" points ? Thanks.
Old 15th February 2012, 08:43 PM   #1918
Zinyx is offline Zinyx  Poland
Point A and B is only for bridge mode, and PRO connect to PRO pin on PA protect. Amp will work without connect A, B and PRO pins.
Old 16th February 2012, 02:54 AM   #1919
Sir. A, b is for bridge configuration and pro is for protection the output power when the power amp is short.
Old 16th February 2012, 02:57 AM   #1920
Sir Mile, im too.
Can I put a logo (APEX B500) on my amplifier box.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
alex mm
900W H-class PA Amp with Limiter apexaudio Solid State 2079 22nd May 2012 02:25 AM
500w power amplifier juneray Solid State 70 16th September 2011 04:05 PM
500W Power Amplifier JRdGreat Solid State 24 16th September 2009 09:48 AM
500W Aleph Amplifier? lscangus Pass Labs 20 19th November 2005 08:29 PM
Looking for 300-500W amplifier audioPT Solid State 3 31st August 2002 12:39 PM
Page generated in 0.10344 seconds (64.73% PHP - 35.27% MySQL) with 11 queries
